![]() | Home > In Car Electronics > Immobiliser LTB00893 Bulletin |
have read this post
https://www.defender2.net/forum/topic59742.html |
sweepc Member Since: 19 Jun 2011 Location: uk Posts: 568 ![]() ![]() |
Thanks dorsetsmith I have had a read through that post and a few others. I was just wondering if anybody had any tips on resolving the issue or dealing with Land Rover regarding the parts etc.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
There have been several LTBs concerning the AS10 and its successor, three of which have been discussed in the linked thread above.
LTB00893 however, as far as I know, covers the case when an AS10 (or the cheap-and-nasty thing that LR replaced the AS10 with when the AS10 became available) becomes unserviceable, and involves the removal of the AS10-type system and its replacement with a number of discrete devices. In effect it is a replacement of the entire alarm and immobiliser system with something completely different. I also believe that it is an expensive modification. |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2297 ![]() ![]() ![]() |
Hello sweepc
In considering your options it may be worth speaking with Paul Brown at Technozone. If your AS10 is at fault this may be one route to see if it can be saved. Paul was extremely helpful to me when I had an intermittent starting problem and was progressively working through the Puma set up to find the fault (Lucus Ignition Switch... Defender used daily 1 non start a month ![]() https://www.technozen-electronics.co.uk/contact/ Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
Thanks guys, I have already read up on all the related posts on the forum. My 10AS unit seems to have totally failed so it won't start at all. Blackwolf the parts for the modification are pretty expensive, I was initially told in excess of £1000 but its a little less. The replacement unit itself is identical however it need a number of other additional components.
Can you get one from a breaker?
Not looked to be honest, I don't know any local breakers that would have one and I wouldn't want to buy something like that online for obvious reasons. Also the unit clearly isn't manufactured very well, I believe it has now been superseded 7 times so I'm told. I wouldn't want to be too far from home only to suffer with the same fault again.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
It shouldn't matter buying one online... you have to synch them with the engine ECU (which the seller won't know), and you can delete any programmed plippers and install your own.
the only thing that would remain the same would be the PUK code thing... you could always get the unit posted to another address (family member?) no where near you. |
I wasn't too bothered about that, I'm just weary about buying parts for newer Defenders online because of the theft issue. Of course I wouldn't have an issue buying from a reputable company but couldn't find any at the time. I'm certainly not going to buy such a unit from just anybody off the internet.
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 249 ![]() ![]() ![]() |
Why not send it off for repair? there is a company that offers that service (on google search.) 1953 80"
1987 mini city e 2011 90" |
that depends on alarm unit late black unit LRJ only |
