![]() | Home > Td5 > Replacing sunroof seal |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 965 ![]() ![]() ![]() |
2nd row seat sunroof in not a standard Land Rover thing... as for removal, just pull the felt/rubber inside trim piece (item 5) off, start at the handle that is where it joins. You should be able to do it all without pulling the roof liner.
![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5918 ![]() ![]() ![]() |
Cheers. I have not seen another one with the same sunroof as mine. From what I can tell it is a standard LR item but in the middle.
I shall have a look over the weekend before I spend £70 on a seal. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
If it is the seal to the glass, you can do it all in situ. Pull the glass out, stand up inside and pry out the seal. It is a PITA to do but if you get the right tools and some silicone spray to mAke it easier, it’ll work.
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 ![]() ![]() ![]() |
id love to see a picture of your install over the seconnd row seats...sounds interesting. Patrick |
That’s funny I have thought about doing that to mine as well but decided it was too much work 😂. I too would like to see that.
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
PaulE Member Since: 29 Apr 2020 Location: East Sussex Posts: 4 ![]() ![]() ![]() |
Here's another solution for those of you with a leaking sunroof, and yes it works. You'll need to purchase 3mm to 5mm thick perspex either clear or tinted (eBay), slightly larger than the existing sunroof, some clear bonding sealant and be handy with either a jigsaw or a fretsaw. Take out and strip existing Sunroof, mark outline onto perspex and then cut approx 5mm within that around the outline including the fixings and clamp mechanism. Check 5mm is enough, the idea is to compress the existing seal down when bonded to the glass roof, so it needs to sit on the seal but not the seal frame. Once cut, assemble and re-position in roof to make sure the roof seals and there are no clashes with existing fixtures. When happy fix perspex to glass using the sealant adhesive. It works, and although makes the sunroof stick-up 3-5mm more does not increase wind noise, not that you'd hear that anyway.
Sorry missed your post. I will nip out when its not raining and take some pics 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
As requested.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I replaced all the seals with new ones and new hinges. I had to add some rubber foam sponge stuff to seal the rear edge (The side where the latch is) as the glass has a curve to it, the glass and seal would not sit together and left a gap. Even with the latch tightened up as much as I could. I tapered each end of the foam to try and match the glass. Lots less in the way of leaks, but still the odd sneaky one appears. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
ijefferyes Member Since: 11 Apr 2020 Location: Radstock Posts: 35 ![]() ![]() ![]() |
Can anyone tell me the part number for just the rubber seal on the sunroof with the twist handle?
All I seem to be able to find is AWR3321 according to lrworkshop. https://www.lrworkshop.com/parts/AWR3321 But this appears to be the whole frame and it is £470. Cheers Ian |
That is the right number, never seen the rubber separately
![]() https://www.lrworkshop.com/diagrams/land-r...roof_44895 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
https://www.ebay.co.uk/sch/i.html?_from=R4...p;_sacat=0
And then I bought https://www.ebay.co.uk/itm/LANDROVER-DEFEN...SwjDZYmbaJ Not sure exactly which item number you are after for you sunroof but on Ebay there is: https://www.ebay.co.uk/itm/GENUINE-LAND-RO...SwgLFelwlF 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
johnnymarrsbarres Member Since: 03 Oct 2024 Location: UK Posts: 19 ![]() ![]() ![]() |
Hi all
My twist handle sunroof was gaffer taped to the roof by the previous owner - I've had the roof repainted so obviously this had to be removed. I've replaced the seal that goes between the glass and the outer frame. I’m finding though that while I think it’s seated properly, the sunroof glass wants to ‘tuck’ in at the front, but sit on top at back. This doesn’t look right to me. See photos attached. Am I doing something obviously wrong here? It seems to sit proud of the frame. Can't find any instructions or information online for love nor money, or even any half decent photos of how it should sit..! ![]() Click image to enlarge ![]() Click image to enlarge |
That does not appear to be the correct seal. Here is my OE factory seal. 🤷♂️
![]() Click image to enlarge ![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
It's this seal I ordered: https://www.lrparts.net/lrc10106-twist-han...patch.html
Which according to the diagram and LR parts site seems to be the one I needed. It also is exactly the right length as it fits in the frame perfectly, just too 'proud'. Would you be able to do me a massive favour and take a couple of close up photos of how the correct seal fits in the outer frame? Can't find decent photos for love nor money...! I suspect I've just put it in wrong somehow - took me sodding ages to get this thing in as it is! |
