Home > Technical > r380 wont go into gear proparly after changing clutch |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 625 |
Try to bleed the clutch system. I had to do it, after changing the clutch, even when I did all to prevent this. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
1st Mar 2019 12:52pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2420 |
I am not sure if a solid clutch disc and solid flywheel is a good combo Puma 110" SW
1st Mar 2019 1:48pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1786 |
Its a bit messy but reverse bleed the system, rotate the slave cylinder so the bleed screw is at the bottom, then with gentle pressure push the fluid in through the bleed screw and overflow the master cylinder, I think I modified an old easi bleed to do it.
Make sure you're outside and have plenty of water to wash the fluid off the bulkhead afterwards. Good luck Keith |
1st Mar 2019 3:11pm |
