Home > Technical > Rear wash/wipe on 300Tdi not working...
Merv Jones
United Kingdom 1996 Defender 90 300 Tdi HT Arles Blue
Went to clean rear window on my 300Tdi on way home yesterday and the wash-wipe no longer works.
I've checked and also changed the fuse (no.3 according to the manual?) - and still no joy.
Do any of you experts out there have any (polite) suggestions ?? Bow down
Post #761191 28th Feb 2019 3:20pm
dorsetsmith
check wiring in the rubber goose neck between door and body maybe you have a broken wire
Post #761193 28th Feb 2019 3:37pm
Merv Jones
Thanks. Just checked that. All looks ok..
But I now notice that the reversing light is not working either....
Does anyone know if the rear wiper/washer and reverse light are linked in any way (apart from the fact they are both at the back of the Landrover that is!)
Tried another bulb in reverse light and still no joy - so it’s not the bulb.....
Post #761220 28th Feb 2019 6:39pm
Martin
Site Admin
Likely to be the earth connection somewhere, the right hand lamps and the rear wiper motor share the same earth path.
Does your rear washer pump work though?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #761221 28th Feb 2019 6:50pm
Merv Jones
No. Pump doesn’t work either.... Sad
Post #761225 28th Feb 2019 7:05pm
Merv Jones
And the reverse light is on left hand side. Not the right.
All of the other rear lights work fine.....
Post #761229 28th Feb 2019 7:25pm
Bongo1
Reverse and brake lights are the same fuse . Are you brake lights working .
i had no power to my heated rear screen , And as Dorsetsmith says check the wires . mine felt looked ok until i decided to re-wire it up , pulling it apart properly and the wire came in half , which i was glad about lol , new section job done .
Earth earth earth . i earth everything
Post #761474 2nd Mar 2019 1:01am
Merv Jones
Thanks all for the replies. Have cleaned earth points and have good news and bad...
Light issue is sorted. Rear wash wipe still a bit hit and miss. Sometimes works. Sometimes doesn’t.
Faulty switch maybe??
Post #761513 2nd Mar 2019 11:48am
Procta
I have a new one going spare, I never got around to fitting, still boxed too Thumbs Up make me an offer on it if your interested Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #762860 11th Mar 2019 6:46am
