![]() | Home > Technical > Rear wash/wipe on 300Tdi not working... |
check wiring in the rubber goose neck between door and body maybe you have a broken wire
Merv Jones Member Since: 13 Nov 2018 Location: Huntingdon,Cambs Posts: 13 ![]() ![]() ![]() |
Thanks. Just checked that. All looks ok..
But I now notice that the reversing light is not working either.... Does anyone know if the rear wiper/washer and reverse light are linked in any way (apart from the fact they are both at the back of the Landrover that is!) Tried another bulb in reverse light and still no joy - so it’s not the bulb..... |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
Likely to be the earth connection somewhere, the right hand lamps and the rear wiper motor share the same earth path.
Does your rear washer pump work though? ![]() ![]() |
No. Pump doesn’t work either....
And the reverse light is on left hand side. Not the right.
All of the other rear lights work fine..... |
Bongo1 Member Since: 02 Nov 2018 Location: Cheshire Posts: 815 ![]() ![]() |
Reverse and brake lights are the same fuse . Are you brake lights working .
i had no power to my heated rear screen , And as Dorsetsmith says check the wires . mine felt looked ok until i decided to re-wire it up , pulling it apart properly and the wire came in half , which i was glad about lol , new section job done . Earth earth earth . i earth everything |
Thanks all for the replies. Have cleaned earth points and have good news and bad...
Light issue is sorted. Rear wash wipe still a bit hit and miss. Sometimes works. Sometimes doesn’t. Faulty switch maybe?? |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5262 ![]() ![]() |
I have a new one going spare, I never got around to fitting, still boxed too
![]() ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
