Home > Maintenance & Modifications > Overfilling Transfer Box - does it do damage?
Scrawf
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Tamar Blue
Today I thought I would replace the oil in my transfer box with some FUCHS TITAN RACE SYN 5. So on the face of it a pretty simple job for an hour or so.
However when I cracked open the filler plug (behind the hand brake drum) about a litre of oil drained out! Hit me square in the middle of the chest! Rolling with laughter
The previous owner or whoever serviced it last must have filled it at the top! And filled it right to the top!
So I was wondering. Could this do the box damage? I could see a fair bit of metal swarf on the magnetic drain plug.
Any thoughts guys?
Scrawf
Post #761007 27th Feb 2019 3:34pm
jst
if its not pressurised it and made it blow a seal, which you would of noticed, then no. it will be fine. LT230 must be the most reliable part of any LR. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #761010 27th Feb 2019 3:47pm
ibexman
Maybe the seal between the main gearbox was leaking
Post #761026 27th Feb 2019 5:05pm
^^^ Not possible on a Puma.
(Well, the seal can leak but oil can't get into the transfer box.)
Post #761058 27th Feb 2019 7:19pm
