![]() | Home > Maintenance & Modifications > Taking the slop out of the drive line |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
An Ashcroft ATB in transfer box would help
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
I have Ashcroft diffs, cvs, shafts drive members and intermediate shaft and no slop!
Have another with Ashcroft cvs, shafts and dms, with very little slop. Both on 70k miles. Both had 20~30k miles on that setup Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2464 ![]() ![]() ![]() |
Everything helps, but the central atb is the most noticeable improvment.
Std central diff shims wear very quickly. Puma 110" SW ............................................................. Earth first. Other planets later |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3706 ![]() ![]() ![]() |
Have you got a link to the central atb? I’m not sure I’m looking at the right thing.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20730 ![]() ![]() |
JST - I will be going the same route as you have, in fact most of it I have already except the CV's / front end.
I only have Ashcroft DM's on the front. ![]() ⛽️🛢️⚙️🧰💪 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17711 ![]() ![]() ![]() |
https://www.ashcroft-transmissions.co.uk/d...-diff.html
ATB in the LT230 as well? |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5929 ![]() ![]() ![]() |
I have a centre ATB and certainly reduced the slop. No the slop shows up elsewhere...namely the rear I suspect.
ATB = good move. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
No, std LT230 on both. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Thanks guys. I’ll go for the atb then, just need to find a log weekend to do the work!
