Home > Maintenance & Modifications > Taking the slop out of the drive line
Co1
Is there an ultimate was to achieve this? I’ve replaced the drive flanges and half shaft which has helped but there is still some movement. Is one piece the answer? I also think I have a bit of slack in the rear diff, is this normal to have some back lash and how much is too much?
What would the ultimate “no slop” driveline be made up of?
Cheers.
PS: It’s a 60,000 mile 13 plate 90.
Post #760878 26th Feb 2019 9:03pm
ibexman
An Ashcroft ATB in transfer box would help
Post #760886 26th Feb 2019 9:34pm
jst
I have Ashcroft diffs, cvs, shafts drive members and intermediate shaft and no slop!
Have another with Ashcroft cvs, shafts and dms, with very little slop.
Both on 70k miles.
Both had 20~30k miles on that setup Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #760887 26th Feb 2019 9:36pm
MK
Everything helps, but the central atb is the most noticeable improvment.
Std central diff shims wear very quickly. Puma 110" SW
Post #760891 26th Feb 2019 9:51pm
Co1
Have you got a link to the central atb? I’m not sure I’m looking at the right thing.
Post #760893 26th Feb 2019 9:55pm
JST - I will be going the same route as you have, in fact most of it I have already except the CV's / front end.
I only have Ashcroft DM's on the front.
Thumbs Up WeWillWin🇬🇧🇺🇸
Post #760906 26th Feb 2019 10:38pm
https://www.ashcroft-transmissions.co.uk/d...-diff.html
ATB in the LT230 as well?
Post #760942 27th Feb 2019 10:17am
excossack
I have a centre ATB and certainly reduced the slop. No the slop shows up elsewhere...namely the rear I suspect.
ATB = good move. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #760998 27th Feb 2019 2:56pm
jst
No, std LT230 on both. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #761009 27th Feb 2019 4:46pm
Co1
Thanks guys. I’ll go for the atb then, just need to find a log weekend to do the work!
Post #761034 27th Feb 2019 6:46pm
