Home > Td5 > 2003 defender td5. Smoke |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Sounds like over fuelling, has the wagon had a remap? If not it could have a slight boost leak. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
25th Feb 2019 10:36am |
divethedeep Member Since: 17 Sep 2014 Location: sussex Posts: 32 |
Just wanted to add. If landrover has sat ideling for a length of time smoke seems worse
25th Feb 2019 12:26pm |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 158 |
It's also possible:
1. MAF issue 2. copper washer at the injectors 3. injector wear and tear 4. turbo issue 5. driver demand (throttle pedal issue) 6. leaking turbo hoses 7. stuck EGR 8. intercooler requires a flush or replacement 9. oil in the ECU From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island. |
25th Feb 2019 12:27pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5732 |
Has it always done this? Just started? Worse when hot/cold?
Have you tried driving it with MAF disconnected? Checked the air filter? Andy |
25th Feb 2019 7:33pm |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 823 |
The fact that it gets worse the longer you idle sounds like a temperature issue. Is the smoke having a blue tint? Wheres your coolant level? I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html |
25th Feb 2019 8:29pm |
It’s had a new maf fitted. (Genuine) Don’t know about cold as drive carefully when engine cold but definatlly hot New air fitted a month ago |
27th Feb 2019 10:21pm |
Could be a leak in the intercooler or its hoses. They show up worse once they have go warm, as they become softer.
27th Feb 2019 11:02pm |
mturri Member Since: 13 Jul 2010 Location: All over Posts: 33 |
Also check your turbo-to-intercooler & intercooler-to-intake manifold hoses for internal delamination (causing air deprivation under medium to high boost conditions).
Have access to live readings via Nanocom or similar? 24 yrs of Td5 ownership D110 Td5 MY06 fully tuned up ex-D2 Td5 MY04 Auto ex-D110 Td5 MY00 ex-D2 Td5 MY00 ex-D2 Td5 MY99 ex-D1 300Tdi MY89 ex-D90 200Tdi MY87 |
28th Feb 2019 3:31am |
