![]() | Home > Maintenance & Modifications > Flatdog Rack and Lazer Light Bar Mounting |
Michaelkan Member Since: 19 Dec 2018 Location: Bath Posts: 149 ![]() ![]() ![]() |
Do I need these? And does this need drilling on the rack? 😢
Tommyharris Member Since: 20 Mar 2018 Location: Bristol Posts: 100 ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
I have a lazer triple r 24 mounted to a hannibal rack and just used the lazer supplied mountings...
![]() Click image to enlarge Just checked and flat dog rack slots go across.... probably will need the hangers. |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 ![]() ![]() ![]() |
I used the standard mounts that came with the Lazer Lamps.
![]() Click image to enlarge Depending on which bar you have, you can use the bolts from the front mounting of the wind break. |
Tartanterror Member Since: 17 Jul 2018 Location: Liphook Posts: 6 ![]() ![]() ![]() |
Hey Tommy - what make and size light bar are you using? Also, would you recommend it? |
