Home > Maintenance & Modifications > Flatdog Rack and Lazer Light Bar Mounting |
Michaelkan Member Since: 19 Dec 2018 Location: Bath Posts: 149 |
Do I need these? And does this need drilling on the rack? 😢
Click image to enlarge |
10th Feb 2019 3:00pm |
Tommyharris Member Since: 20 Mar 2018 Location: Bristol Posts: 100 |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
21st Feb 2019 10:48pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2654 |
I have a lazer triple r 24 mounted to a hannibal rack and just used the lazer supplied mountings...
Click image to enlarge Just checked and flat dog rack slots go across.... probably will need the hangers. |
22nd Feb 2019 1:42am |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 |
I used the standard mounts that came with the Lazer Lamps.
Click image to enlarge Depending on which bar you have, you can use the bolts from the front mounting of the wind break. |
22nd Feb 2019 6:41pm |
Tartanterror Member Since: 17 Jul 2018 Location: Liphook Posts: 6 |
Hey Tommy - what make and size light bar are you using? Also, would you recommend it? |
4th Jul 2019 12:34pm |
