Home > Defender Celebration Series & Classic Works > Adventure Warranty - Expedition Rack and Aluminium guards
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
Anyone had success with warranty claims due to corrosion of
1. Roof rack - mine has pin holes through powder coat with visible rust. There are some bubbles too, at the welds.
2. Aluminium steering guard and side guard corrosion.
 Current Steeds:
2015 110 UW in Grasmere Green
2003 BMW F650 the Hack
2000 Elise
1992 Ducati 888 (no longer in bits, yahoo)
1990 TDR 250 (in bits again)
1988 TDR 250 (no longer in bits) and for sale
Post #760104 22nd Feb 2019 12:31am
steve E
Wales
I had the same problem with the roof rack and the dealer ordered me a replacement but the replacement was even worse.
There was no problem with them doing it, just the quality of the rack full stop.
Post #760138 22nd Feb 2019 9:45am
doublea
Land Rover have approved warranty works for the rack and aluminium guards, on account of corrosion.
Given the comments on the poor quality of replacement racks, I'll have to give the replacement a good look over. It's a pity I couldn't get them to fit a Hannibal instead!
The guards are now declared obsolete, I suppose since they were made by Mantec, the new company won't see these as a viable product to re-start manufacture and Land Rover probably doesn't have any stock since the last of the Adventures were sold.
The local repairer has said they can lacquer/paint or powder coat these to in effect, refinish them. What would be the best option? I'm a bit wary of powder coat in case of corrosion underneath, unseen.
They're not all that bad, it's just cosmetic...
But they're not like they were either
 Current Steeds:
2000 Elise
Post #768804 16th Apr 2019 9:23am
lohr500
Are there any intentional holes in the roof rack frame?
I'm just wondering if a good blast of Dinitrol into the inside of the tubing might help in preventing corrosion from the inside out.
Given the reported quality issues, it might even be worth considering drilling a small unobtrusive hole into each tubing section to blast in some rust preventative.
Post #768810 16th Apr 2019 10:27am
dotom
Germany 2016 Defender 90 Puma 2.2 XS CSW Corris Grey
Hi doublea, I've got the Adventurer side sills for my 90 from Mantec. I've got them sandblasted with very fine material and anodized by a company which is specialized on this. They do that for Audi and BMW cars normally, so it should last.
I have it for 2 years now - and also 2 winters with lots of salt - and they still look good. If it's starting to get worse, they can do it again.
Regards
Tom
Post #768824 16th Apr 2019 12:57pm
timthepom
United Kingdom 2015 Defender 110 Puma 2.2 Adventure Corris Grey
I’ve got the same corrosion issues with the rock sliders and sump guard on my 2015 Adventure edition. Starting to look a bit grotty. Anyone know of any specialists in the UK that can refinish them? Is galvanising an option?
Post #786127 10th Aug 2019 3:20pm
Sulisuli
Timthepom a local fab shop near to me in Cornwall May well be able to help you, if you want to pm me I will give you a contact name and number Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #786132 10th Aug 2019 4:00pm
You can't galvanise aluminium, I'm afraid. I think the best finish would be to have them anodised. Either that or paint, but only if properly prepared. Darren
Post #786142 10th Aug 2019 5:16pm
doublea
It turned out the side protection is no longer available from JLR, but the front is, probably because it's a part common to both 90 and 110 and perhaps most likely to suffer impact damage.
JLR agreed to have mine anodised, but after treatment the finish was poor, most likely as they were not prepared properly. I doubt either the bodyshop or anodiser bead blasted them. So the bodyshop painted them silver and they look great, for the moment.
Post anodising
The racks were replaced with new ones and look pretty good. I ran about in the 110 without the rack for a few weeks but it just didn't look like an Adventure, so it's back on again. Current Steeds:
2000 Elise
Post #786192 10th Aug 2019 8:13pm
