Home > Technical > strange problem transferbox defender td5 2001 |
Spin the knob 180 degrees, carry on.
9th Feb 2019 10:00pm |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
If Greeni’s suggestion doesn’t work, you could try facing backwards in the car.
HTH. Sorry, I have no idea either 2014 Keswick Utility 2.2 |
20th Feb 2019 10:39pm |
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 |
Well those are encoureaging answers...
OP could probably have been more specific though. Recently a similar problem has been discussed on lr4x4 as far as it concerns throttle response - I presume that's the problem that the topicstarter refers to: https://forums.lr4x4.com/topic/55396-td5-hilow-switch/ Greetings, Joris Antares Treadwell, a MY06 110 Td5 in Chawton White |
21st Feb 2019 12:23am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6112 |
Has anyone been working on the vehicle and put the linkage in the wrong way round?
21st Feb 2019 10:49am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17527 |
I think that the OP needs to clarify if he's asking about throttle response or about gearing before any meaningful help is forthcoming.
I suspect that it is more likely to be throttle response (and a wiring issue with the high/low switch) than a gearing issue, but clarification would help. |
21st Feb 2019 10:57am |
