Home > Technical > strange problem transferbox defender td5 2001
Bert@E
Netherlands
hello,
i have a strange problem with my newly acquired defender transferbox.
if i put the lever of the transferbox in the top position the car acts like its in high gear and if i put it in the lower position it acts like its in low gear?
any advice?
thx
Post #757641 9th Feb 2019 9:13pm
Spin the knob 180 degrees, carry on.
Post #757651 9th Feb 2019 10:00pm
UtilityTruck
If Greeni’s suggestion doesn’t work, you could try facing backwards in the car.
HTH.
Very Happy
Sorry, I have no idea either 2014 Keswick Utility 2.2
Post #759920 20th Feb 2019 10:39pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Well those are encoureaging answers...
OP could probably have been more specific though.
Recently a similar problem has been discussed on lr4x4 as far as it concerns throttle response - I presume that's the problem that the topicstarter refers to:
https://forums.lr4x4.com/topic/55396-td5-hilow-switch/
Greetings,
Joris Antares Treadwell, a MY06 110 Td5 in Chawton White
Post #759924 21st Feb 2019 12:23am
Has anyone been working on the vehicle and put the linkage in the wrong way round?
Post #759967 21st Feb 2019 10:49am
I think that the OP needs to clarify if he's asking about throttle response or about gearing before any meaningful help is forthcoming.
I suspect that it is more likely to be throttle response (and a wiring issue with the high/low switch) than a gearing issue, but clarification would help.
Post #759970 21st Feb 2019 10:57am
