Home > Td5 > Exhaust upgrades?
Defender Fun
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
Exhaust upgrades?
Hi
I have a TD5 defender i would like to put a performance exhaust system and to gain that famous 5 cylinder roar. i understand the turbo whistling and true burble comes when you fit a decat and a straight through silencer (i had this on a previous td5) but now with regulations tightening is there a way to get this noise from an exhaust system on the market that still has the cat to keep it road legal?
Kind Regards
Post #759435 18th Feb 2019 5:28pm
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
I have a straight through but retain the cat, passed its MOT ok.
You could always go for a 3 inch, but I understand this affects wading depths. I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #759437 18th Feb 2019 5:44pm
Iโ€™d look at an Alive CAT back system myself. If you went 3โ€ you might find the noise a bit annoying in the long term $W33T $0U7H3RN $UG4R
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #759438 18th Feb 2019 6:02pm
Defender Fun
Hi
thank you for your reply, wading or off roading isn't a problem for me as i dont intend to go mega off roading. i currently do have a straight through centre box but it hasnt made a difference.
kind regards
Post #759439 18th Feb 2019 6:03pm
Defender Fun
HI
Thank you for your reply, do the 3 inch systems fit well or is there any modifications needed?
Post #759440 18th Feb 2019 6:04pm
ibexman
Griffin ๐Ÿค”
Post #759442 18th Feb 2019 6:08pm
Defender Fun
Hi
do griffin charge roughly the same as Alive for their exhausts?
Post #759444 18th Feb 2019 6:14pm
I canโ€™t really comment on the system but was just a suggestion to look at I would be intesteded in. It may in fact be 3โ€?
Griffin indeed do get good reviews too, and a bit cheaper but Iโ€™d still go for Alive but everyone can make up their own mind. $W33T $0U7H3RN $UG4R
Post #759450 18th Feb 2019 6:45pm
Mdm
the griffin looks ok and sounds good, loud when you work it for sure
the twisted one i think sounds a little better with more turbo spool noise as it loads up.
without any boxes its too loud and boomy at certain speeds and you need some back pressure in the system to make the best of the td5.
Post #759452 18th Feb 2019 7:14pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Allisport also make one with a dummy cat shell and a slimline silencer.
Iโ€™ll be tempted to get their cat back system (as mines a 2001 pre cat)
Post #759512 18th Feb 2019 10:35pm
landy andy
Alive one is better than Griffin. Iโ€™ve had both, and really you need to loose the cat for the best results. Think both complies do dummy cats, or did anyway.
Post #759514 18th Feb 2019 10:39pm
Djcla
http://www.alivetuning.com/product/defende...s-exhaust/
How does this work for post 02 cars with a cat then , not sure I understand?
Post #759632 19th Feb 2019 6:13pm
JOW240725
You could try speaking to Demand Engineering, which I've recently discovered make exhausts for some previously mentioned companies. James
Instagram @suffolk_rovers
Post #759638 19th Feb 2019 6:35pm
It's CAT back, so the existing CAT stays in situ, the piping and its flange. The rest of the system would be the newsystem from there back.
Thumbs Up $W33T $0U7H3RN $UG4R
Post #759640 19th Feb 2019 6:38pm
Djcla
Thanks Steve
Post #759647 19th Feb 2019 7:03pm
