![]() | Home > Td5 > Exhaust upgrades? |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
I have a straight through but retain the cat, passed its MOT ok.
You could always go for a 3 inch, but I understand this affects wading depths. I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
I’d look at an Alive CAT back system myself. If you went 3” you might find the noise a bit annoying in the long term Chillin In The Backwoods🇬🇧🇺🇸
Defender Fun Member Since: 03 Feb 2019 Location: South East Posts: 64 ![]() ![]() ![]() |
Hi
thank you for your reply, wading or off roading isn't a problem for me as i dont intend to go mega off roading. i currently do have a straight through centre box but it hasnt made a difference. kind regards |
HI Thank you for your reply, do the 3 inch systems fit well or is there any modifications needed? |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2956 ![]() ![]() |
Griffin 🤔
Hi
do griffin charge roughly the same as Alive for their exhausts? |
I can’t really comment on the system but was just a suggestion to look at I would be intesteded in. It may in fact be 3”?
Griffin indeed do get good reviews too, and a bit cheaper but I’d still go for Alive but everyone can make up their own mind. Chillin In The Backwoods🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1635 ![]() ![]() |
the griffin looks ok and sounds good, loud when you work it for sure
the twisted one i think sounds a little better with more turbo spool noise as it loads up. without any boxes its too loud and boomy at certain speeds and you need some back pressure in the system to make the best of the td5. |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 ![]() ![]() ![]() |
Allisport also make one with a dummy cat shell and a slimline silencer.
I’ll be tempted to get their cat back system (as mines a 2001 pre cat) |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Alive one is better than Griffin. I’ve had both, and really you need to loose the cat for the best results. Think both complies do dummy cats, or did anyway.
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 ![]() ![]() |
http://www.alivetuning.com/product/defende...s-exhaust/
How does this work for post 02 cars with a cat then , not sure I understand? |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
You could try speaking to Demand Engineering, which I've recently discovered make exhausts for some previously mentioned companies. James
It's CAT back, so the existing CAT stays in situ, the piping and its flange. The rest of the system would be the newsystem from there back.
Thanks Steve
