Home > Technical > rear windowns falling down? ghost?
big110
2014 Defender 110 Puma 2.2 SW Keswick Green
seems like on a REGULAR basis i find me rear passenger windows about 1/2" down. Is this a known defender thing? Such a pain.
Post #758495 13th Feb 2019 9:59pm
Yes, it is a well-known feature. There are solutions, which vary from moving the handles round a bit on their spigots, through bungee straps, to fitting electric lift motors.
Post #758501 13th Feb 2019 10:13pm
big110
ahh move them around to the facing down position?
Post #758502 13th Feb 2019 10:15pm
landy andy
Just move the handles so they are in a position that down of the handle would make the window raise. That way as they vibrate they will be forcing the window shut, not opening it.
It’s worked for my last two Defenders.
Thumbs Up Thumbs Up
Post #758509 13th Feb 2019 10:26pm
big110
Easy to remove? Landy isn’t here at the moment
Post #758510 13th Feb 2019 10:31pm
donmacn
Thanks for posting the question! Obviously I didn't know it was a common thing. I'll be rebuilding new 2nd row doors soon - I'll make sure the winder is properly placed! Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #758514 13th Feb 2019 10:48pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Having same problem, thanks I'll adjust mine also.
Post #758516 13th Feb 2019 10:51pm
Doc P
Yes. The winder handle is held onto the spline of the winder by a small circlip which engages with a groove in the spline (I’ll send a photo if I get a minute). Wrap a piece of thin cloth around the base of the handle and slide it back and forth (whilst pulling it in the direction of the base of the handle) and that’ll pop the clip off - just don’t ber-ding the clip onto the lawn like I did!
Post #758936 16th Feb 2019 8:19am
Mine used to drop irrespective of the knob position, and I used to have a short loop of bungee round the knob and door handle to stop this. The permanent cure was to fit an electric lift kit to the second row.
Post #758950 16th Feb 2019 9:14am
donmacn
^^^^^ irrespective of position...
I was thinking about this, and came to more or less the same conclusion. If the window is dropping, then the weight of the glass, plus the winder 'gubbins' is going to be so much heavier that a small plastic handle, surely? If the window wants to drop,I guess it will just drop - unless you lock the handle somehow.
I assume another solution is to make sure that the window channels/felts, and the internal and external waist seals are in good nick.
Changing all of that is much more involved though, so a bungee on the winder sounds like a cunning plan in the meantime. Donald
in the past..
Post #758954 16th Feb 2019 9:26am
landy andy
Two 110s. Both used to have dropping rear windows. Moving the handles sorted the problem on all for me.
Post #758957 16th Feb 2019 9:46am
donmacn
Cool! Happy to be proved wrong. I'll certainly try that first. Donald
in the past..
Post #758964 16th Feb 2019 10:04am
landy andy
I’m not saying your wrong, just that it has worked for me.
It a Defender, so nothing it definite Thumbs Up
Post #758965 16th Feb 2019 10:33am
I think it all depends on how much friction there is in the mechanism. If enough, then adjusting your knob will do the trick. On mine, however I positioned my knobs the glass would drop, so this lead to the bungee-round-the-knob trick which sorted the problem. The electric solution is better though.
Post #758979 16th Feb 2019 12:35pm
landy andy
Have you a link to your electric window install? Would be a nice extra. Was surprised it wasn’t on my Tdci rears.
Andy.
Post #758980 16th Feb 2019 12:52pm
