- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
shropshiredefender
Apparently - "Control module input power A" AAAh read your post properly - you already knew that
Not a clue what that means
No doubt someone more helpful will be along soon
11th Feb 2019 7:37pm |
sloderby1
From the JLR diagnostic description document:
There are actually 3 codes under this number - denoted by the subsequent failure type value:
U3006-16 Control Module Input Power "A" circuit voltage below threshold
U3006-17 Control Module Input Power "A" circuit voltage above threshold
U3006-1C Control Module Input Power "A" circuit voltage out of range
The symptoms for these in turn are noted as:
U3006-16 Possible EBD Warning Lamp ON ABS Warning Lamp ON TCS Warning Lamp ON
U3006-17 EBD Warning Lamp ON ABS Warning Lamp ON TCS Warning Lamp ON
U3006-1C ABS Warning Lamp ON TCS Warning Lamp ON
Clearly these are all related to the power input to the ABS module, which the documentation lists as pins 7, 16 & 35 of the ABS
Hope this helps
11th Feb 2019 8:06pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
