Home > Puma (Tdci) > Fault Code U3006 |
Matilda110 Member Since: 02 Jun 2015 Location: Aberdeenshire Posts: 4 |
The traction control on my 2011 110 comes on when pulling away from rest in first gear regardless of the road conditions. Fault code U3006 - Control module input power A - was found when the Landy was in for a service at my local garage - what does this actually mean? Is it related to the TC issues?
11th Feb 2019 5:44pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
Apparently - "Control module input power A" AAAh read your post properly - you already knew that
Not a clue what that means No doubt someone more helpful will be along soon |
11th Feb 2019 7:37pm |
Thanks, bearing in mind this seems to be an ABS/TC issue, could it be a faulty speed sensor?
11th Feb 2019 8:45pm |
