Home > Puma (Tdci) > Clicking/knocking noise.... |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 400 |
If it sounds a bit like somebody cracking their knuckles and is worse when you have steering lock on, then I'd suspect CVs. A really bad UJ will start to bind up (just before it goes bang and the propshaft tries to tunnel its way through the floor) so may be worth chocking the wheels, letting the handbrake off and getting under to give those a shake (no point doing it with the handbrake on as any load on the rear propshaft will take up slack). ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
10th Feb 2019 11:23am |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 429 |
As above check your UJs. Although also check your tire tread for a stone.
10th Feb 2019 2:04pm |
