Home > Puma (Tdci) > Saggy bottom!
toshers
Scotland 2011 Defender 110 Puma 2.4 USW Orkney Grey
Saggy bottom!
I've noticed that my Puma is sitting down at the rear slightly. Probably as a result of what I've fitted in the back!
I'd rather not fit HD springs and end up with a harsh ride. Have looked at the possibility of getting a 1" pair of raised rear springs to compensate but not sure of this option!
What do folks recommend as a possible way forward? Anyone been here before and implemented a solution they're happy with?
Post #75750 14th Jun 2011 7:53am
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Mine's had HD suspension from new, and from what I've seen when parking it next to other Defenders, it makes no difference to the ride height at all. I don't think it makes the ride quality harsh either, I actually think it's a bit of an improvement on the standard.
I think you're going to have to go down the 'longer spring route'.
Pete
Post #75754 14th Jun 2011 8:22am
ibexman
fit some discover1 sprong isolaters they will give you an extra 10mm to trim the car up Thumbs Up Thumbs Up
Post #75755 14th Jun 2011 8:48am
toshers
Does anyone recommend some standard height HD springs for the rear?
Post #75780 14th Jun 2011 12:35pm
mse
all the std 90 xs have heavy duty rear springs (well mine did)
Great to put loads on...but makes the ride harsh (for back seat passengers!!) Mike
Post #75813 14th Jun 2011 4:47pm
markb110
Hi Tosher
Also worth a look are the spacers that Gwyn Lewis has. Available as 1 - 1.5 or 2 inch.
I fitted the 1 inch all round on my 90. They replace the standard spring seats on top of the axle ( and dont cost too much)
www.gwynlewis4x4.co.uk
Hope that helps
Mark
Post #75819 14th Jun 2011 5:07pm
toshers
These look just the job Thumbs Up
Post #75840 14th Jun 2011 5:58pm
Matt
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Yeah, genuine LR HD springs Thumbs Up Thumbs Up
Post #75850 14th Jun 2011 6:52pm
