Home > Tdi > Wiring up discovery 300tdi into early 90 loom
Ae-Richy
Hi there. I am currently building a hybrid 88” for off-roading. I am using a discovery chassis and running gear. It is a 300tdi auto that I am using as a donor car. I have the bulkhead mounted from an early 90 mounted (glass fuses fitted) ! I was wondering if anyone has any wiring guides/diagrams of what and where I need to mate everything up to?? Any help would be very much appreciated! Cheers folks.
Post #755365 31st Jan 2019 9:44pm
Procta
Might worth you looking for a second hand Defender 300 TDi full loom to make everything plug and play, Or look into using the disco loom into the defender.
But my money would be on finding a defender 300 TDI loom. I have done an engine conversion before in a rover metro, and i replaced the full electrics with a later R100 system, which made things more OEM and plug and play.
The last thing you want is faffing about Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #757377 8th Feb 2019 6:59pm
