Home > Td5 > Wing top, sills and rear quarter Chequered plating |
D90JAP Member Since: 13 Jan 2019 Location: Aberdeen Posts: 14 |
Hi folks,
Looking to Chequer plate as the above. Looking for 3mm in black but found there are a few different manufactures with different style wing tops. What are people recommendations with pictures of there’s and where they came from. Would have probably left them but wing tops where already dented when purchased the vehicle. Thanks Jack |
7th Feb 2019 8:38pm |
The Mammoth brand is OEM, I believe. Darren
7th Feb 2019 9:34pm |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 879 |
Did a lot of research and I was told to go for Mammouth. Bought mine from LRParts in black but I'd ask Brendon if he sells good stuff too.
Mine is a 110CSW. Items numbers for the lower vehicle sills and rear quarter are: SLKIT01-CSW/B CNKIT02-110/B Wing tops depend on if you have the Ariel fitted and if you want the gasket. , but I believe on the Pumas, mammoth finish the plate before the airiel. Best to give them a call and check. I didn't do my wing tops as I didn't want to regret the decision and have holes in the bonnet. |
8th Feb 2019 2:04am |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 |
As PCM said, chequer for Puma wingtops is narrower/shorter at the bulkhead end due to a Puma bonnet being slightly wider.
I've fitted Mammouth stuff before and very pleased with it 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
8th Feb 2019 5:52am |
