Home > Td5 > Wing top, sills and rear quarter Chequered plating
D90JAP
Scotland 2004 Defender 90 Td5 HT Epsom Green
Hi folks,
Looking to Chequer plate as the above. Looking for 3mm in black but found there are a few different manufactures with different style wing tops.
What are people recommendations with pictures of there’s and where they came from.
Would have probably left them but wing tops where already dented when purchased the vehicle.
Thanks
Jack
Post #757178 7th Feb 2019 8:38pm
The Mammoth brand is OEM, I believe. Darren
Post #757215 7th Feb 2019 9:34pm
landy andy
Mammouth stuff is nice quality, with good fittings and is neatly bent/formed over the front and side of the wing. I’m sure Brendan at 4x4 overland will also have some good quality German stuff too.
Post #757231 7th Feb 2019 10:38pm
PCM
Did a lot of research and I was told to go for Mammouth. Bought mine from LRParts in black but I'd ask Brendon if he sells good stuff too.
Mine is a 110CSW. Items numbers for the lower vehicle sills and rear quarter are:
SLKIT01-CSW/B
CNKIT02-110/B
Wing tops depend on if you have the Ariel fitted and if you want the gasket. , but I believe on the Pumas, mammoth finish the plate before the airiel. Best to give them a call and check. I didn't do my wing tops as I didn't want to regret the decision and have holes in the bonnet.
Post #757246 8th Feb 2019 2:04am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
As PCM said, chequer for Puma wingtops is narrower/shorter at the bulkhead end due to a Puma bonnet being slightly wider.
I've fitted Mammouth stuff before and very pleased with it Thumbs Up 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #757251 8th Feb 2019 5:52am
