Home > Maintenance & Modifications > Puma Rear Top Brake Lights |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
Check the tracks on the rear window particularly where they pass under the plastic brake light cover. They are prone to being rubbed through. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
24th Jan 2019 4:38pm |
Michaelkan Member Since: 19 Dec 2018 Location: Bath Posts: 149 |
Ok will take apart the brake light tomorrow morning. Thanks.
24th Jan 2019 4:57pm |
Only bad thing I found is this. It seem it didn’t have a good contact. It seem I need a solder iron for this.
Click image to enlarge |
25th Jan 2019 12:47pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
Or you could do it the easy way with 1xM 1xF connectors and a suitable length of cable which can be inserted between glass and rubber seal, replacing the need for the fragile printed track
25th Jan 2019 1:40pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Mine did exactly that and I found broken wire in the loom inside the rubber from tub to door check there first 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
25th Jan 2019 6:59pm |
Same job done on mine!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
25th Jan 2019 11:48pm |
Did exactly that. Was waiting for my multimeter to arrive. Apparently earth on the element seems dead. So new cables and while at it installed a new LED brake light. Thanks for the help. |
5th Feb 2019 12:45pm |
