Home > Maintenance & Modifications > Puma Rear Top Brake Lights
Michaelkan
United Kingdom 2011 Defender 110 Puma 2.4 SW Santorini Black
I noticed my third brake light is not illuminate when I pressed on the brakes. Thought it was the bulb. Changed to a new one and still no light. Fuse 15amp for the brakes is fine. What else can go wrong? Where is the earth location for the brake lights? Any ideas? Thanks. [/img]
Post #753673 24th Jan 2019 4:19pm
Martin
Site Admin
Check the tracks on the rear window particularly where they pass under the plastic brake light cover. They are prone to being rubbed through.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #753679 24th Jan 2019 4:38pm
Michaelkan
Ok will take apart the brake light tomorrow morning. Thanks.
Post #753683 24th Jan 2019 4:57pm
Michaelkan
Only bad thing I found is this. It seem it didn’t have a good contact. It seem I need a solder iron for this.
Post #753862 25th Jan 2019 12:47pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Or you could do it the easy way with 1xM 1xF connectors and a suitable length of cable which can be inserted between glass and rubber seal, replacing the need for the fragile printed track Thumbs Up
Post #753876 25th Jan 2019 1:40pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Mine did exactly that and I found broken wire in the loom inside the rubber from tub to door check there first 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #753929 25th Jan 2019 6:59pm
dgardel
Italy
Same job done on mine!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #753979 25th Jan 2019 11:48pm
Michaelkan
Did exactly that. Was waiting for my multimeter to arrive. Apparently earth on the element seems dead. So new cables and while at it installed a new LED brake light. Thanks for the help.
Post #756497 5th Feb 2019 12:45pm
