Home > Puma (Tdci) > Noise on starting from cold - 2.2 Puma 29K
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
Over the past six weeks or so, the 110 has been making a whining noise from the front of the engine, most noticeable in front of the radiator.
It only happens on the first start of the day and becomes intermittent then stops after about 120 seconds. The time has been a little less when the weather has been slightly warmer. It's like a low horn noise.
Any ideas?
Thanks, Doublea
https://1drv.ms/v/s!Ar-D0Wz_PaxDkk9Urgv3QexGfIu9
PS not sure of the best way to post videos, hopefully this works. Current Steeds:
2015 110 UW in Grasmere Green
2003 BMW F650 the Hack
2000 Elise
1992 Ducati 888 (no longer in bits, yahoo)
1990 TDR 250 (in bits again)
1988 TDR 250 (no longer in bits) and for sale
Post #695105 21st Mar 2018 12:12am
Balvaig
Possibly a loose or worn serpentine belt. Often screech at startup.
Post #695137 21st Mar 2018 8:14am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Also check the tensioner arm and the pulleys (and their bearings). The normal service interval of the serpentine belt is around 60k miles so at 29k miles, it shouldn't be loose and or worn. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #695150 21st Mar 2018 9:23am
doublea
Showed the video to the mechanic when the 110 was in for end of warranty check - he reckoned it was the viscous fan was at fault. Current Steeds:
2000 Elise
Post #695795 23rd Mar 2018 11:12pm
zsd-puma
10 years or 120k miles on a Puma. Doesn't hurt to do it sooner though.
I'd agree with the mechanic, does sound more like a faulty fan coupling than a belt slipping. Could be the electric A/C fan too. You could unplug the A/C fan and see if the noise stops. But if it's under warranty why bother, just let the garage do it. Wink
Post #695807 24th Mar 2018 12:00am
I done mine at 60k.
Mine slipped on start up occasionally in cold weather, causing a small screech.
Since changing the belt it's perfect now.
Any chance any oil or slippery substance has contaminated the mating surfaces? I guess it's hard to tell though. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #695808 24th Mar 2018 12:08am
doublea
The viscous fan coupling was replaced last March under warranty. By then the weather warned up and the noise was gone.
With the recent colder weather, the low horn noise has returned, so it wasn't the fan. Given that it goes away within a few minutes of start, could it be the water pump, which is warmed fairly quickly by the engine firing? Current Steeds:
2000 Elise
Post #756097 3rd Feb 2019 11:03pm
It could be the bearing but typically it's belt slip, after a short time the belt its self would warm I would have thought and grip more and thus noise gone.
I would change the seppentine belt, they are not hard to change no special tools needed at all.
Just be careful of fingers with tensioner that's about all. Thumbs Up
Then you could rule it out if not, for little cost. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #756107 4th Feb 2019 12:02am
