Home > Puma (Tdci) > How difficult is the replacement of my turbocharger.
Persepolis
Netherlands 2008 Defender 110 Puma 2.4 SW Java Black
Good morning,
How difficult is it to replace the turbocharger yourself?
I have a Defender 110 Puma 2.4 from 2008. The car still has the original turbocharger without a remap.
What I thought:
1 - change oil
2 - remove the turbocharger
3 - clean contact surfaces
4 - put run-in oil in turbocharger.
5 - replace the turbocharger with a new gasket set.
6 - start car and run stationary for 15 minutes
7 - Make test driving with not to much rpm.
8 - job is done
I hope to have all the right steps in my changing plan?
I hope for your reaction.
Thank you
Mario
Post #755630 2nd Feb 2019 6:59am
landy andy
Very easy, but fiddly due to the engine not being designed for the Defender, so silly things like you can’t just remove the nut off the stud, you have to remove the studs themselves. Also the dipstick and it’s tube need to be removed. All simple but fiddly, but nice work.
Andy.
Post #755637 2nd Feb 2019 7:33am
Persepolis
Hi Andy,
Thank you for your reaction
What do you mean with "Also the dipstick and it’s tube need to be removed"
What is the relation to the replacement? Is it because of the change of oil? or is it in the way of the replacement?
Mario
Post #755640 2nd Feb 2019 7:52am
landy andy
It’s in the way, possibly threaded through it. It’s just a case of removing one bolt, and twisting it up and out they way, getting it back in is a bit like the games you get in a Xmas cracker where for a while it appears impossible, but then lines up, and drops in. Sounds worse than it is. I haven’t done one for a few years, but got very quick at it when I had a Tdci.
Post #755646 2nd Feb 2019 10:02am
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
I’ve had the joy of changing mine twice and yes it is a bit fiddly. The dipstick wasn’t an issue for me but the oil return pipe is a sod to get the bolts back in. I used a a super long extension bar from underneath.
There’s a bracket for the exhaust near the bottom of the engine which needs to be undone and you can pull the downpipe back far enough then without having to take it off completely.
Some turbo manufacturers insist you change the oil feed pipe for the warranty. That’s nearly 100quid for one and a lot of dismantling to change.
I can thoroughly recommend the Nakatatenga turbo gasket. I’ve had two genuine ones blow and these are solid. Well worth the money.
When I changed mine I changed the oil, then again after another 500 miles. No problems since (touch wood)
Dave
Post #755653 2nd Feb 2019 10:37am
mata
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
i 'helped' my mechanic swap mine a few months ago.
Very long extension bars to get the nuts off the turbo and to get to the engine end of the oil feed pipe (which needs replacing with new ideally) the serpentine belt needs to come off followed by the alternator off and out from underneath.
Im glad i didn't try and do it myself on the driveway.
Post #755693 2nd Feb 2019 2:34pm
landy andy
Yes maybe it was the oil rtn pipe. I didn’t remove the alt or its drive belt any time I’ve done mine though.
Post #755694 2nd Feb 2019 2:53pm
Persepolis
Dave
Hi Dave,
Only out of curiosity, Why did you change your turbocharger twice?
Do i understand you well, that you changed oil after 500 miles after changing the turbocharger?
Regard from a sunny Amsterdam
Mario
Post #755846 3rd Feb 2019 8:58am
landy andy
Just to show you the quality, or not, of a Tdci turbo.
Post #755857 3rd Feb 2019 9:23am
Persepolis
Hi Andy,
What is this? What happend? Unbelievable.
Rolling with laughter
I think you didn,t laugh! It is a Garrett turbo. I though it was the best brand on the market.
Is it a revision turbocharger?
Post #755873 3rd Feb 2019 10:09am
landy andy
Standard turbo, and it warped, sorted that, then it snapped due to being thin metal, and poor quality. Removed the bloody thing about three or four times. In the end I got shot of the Tdci and went back to a good old Td5. When casting is weaker than some studs it gives you an idea of the construction.
Post #755887 3rd Feb 2019 11:21am
Michael Brindley
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Mine left the side of engine completely with a loud bang.
Post #859187 1st Oct 2020 7:59pm
landy andy
I bet it did go with a bang.
Top quality. Not Rolling with laughter Rolling with laughter
Post #859239 2nd Oct 2020 6:51am
Wow! Did you find out why?
Post #859259 2nd Oct 2020 8:11am
Michael Brindley
No had had one fitted by dealer under warranty at 16,000 miles due to mass airflow faults.This one went at 73,000 miles.Had BAS updrade at 60,000 miles and perhaps needed intercooler too at same time.Origional intercooler went at 82,000 miles so had BAS upgrade one fitted So perhaps we will never know.Had recon turbo exchange from turbo technics as it was only one avaiable at time but seem ok
Post #859822 4th Oct 2020 7:27pm
