Home > Puma (Tdci) > Door Lock Barrel
Yeti110
Sweden
Door Lock Barrel
Hello. I'm appealing to anyone with advice or experience of my new problem.
My driver's door key will no longer turn the lock barrel. The door will lock and unlock manually from inside, as normal.
It is not frozen.
After work, I'll remove the door card and wondered if this problem sounds familiar to anyone?
Many thanks....
Post #755418 1st Feb 2019 10:06am
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
hmm, i had a similar problem and found that a map gas torch can melt the barrel out because mine was seized
Post #755424 1st Feb 2019 10:35am
Yeti110
Sweden
It definitely feels seized.
Sorry I don't understand, do you mean you needed the gas torch to remove the barrel?
Post #755426 1st Feb 2019 10:42am
VVS210
He means to defrost the lock barrel but you've said its not frozen. Sounds to me as if one of the 'tumblers' is stuck up, try using a bit of light oil & work the key in & out to see if you can free it up. If that fails take the door card off, remove the little C clip from the end of the lock & withdraw the barrel & cylinder from the door to see what the problem is.
P.S. The trick I always used when the lock was frozen was to insert the key then heat it gently with a cigarette lighter so the heat transfers down the key to the lock & melts any ice. Also used the lighter to melt the ice in the push button as well.
Post #755436 1st Feb 2019 11:50am
windy81
I actually meant melt the whole barrel, map gas will melt it out quite easily.
Post #755440 1st Feb 2019 12:00pm
Yeti110
Sweden
I see. Thanks for your replies.
You're correct. I removed the barrel and when I push the key in, a few of the brass pins remain projecting out of the barrel.
I assume they should all disappear flush with the tumbler, and that is what's causing the problem!?
Post #755455 1st Feb 2019 12:40pm
Yeti110
Sweden
Post #755456 1st Feb 2019 12:41pm
Michaelkan
United Kingdom 2011 Defender 110 Puma 2.4 SW Santorini Black
U can take the pins out, oil the barrel and put it back in sequence. The spring might seized. Else get a new barrel and remove the new pins and match the old pins so u can use your old key.
Post #755464 1st Feb 2019 1:39pm
Yeti110
Sweden
Thanks for giving me the confidence to do that.
All working again. Took the lock barrel apart and one of the pins had crushed it's spring. Got rid of that one and it works fine now...
Thanks so much-
Cheers, Yeti110
Post #755486 1st Feb 2019 3:54pm
