Home > Technical > DSC Fascia Switch. Where does it terminate? |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2314 |
According to the below image '18' is the DSC switch. I have a blank fitted in this position so intend to use the circuit to switch an LED light bar (via relay)
So where does the feed terminate? Presumably I should find a plug somewhere in the engine bay? Click image to enlarge > 110 XS Double Cab |
29th Jan 2019 8:33am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6634 |
The DSC switch and wiring is only fitted on the Defenders with DSC, which is all of them from 2015 model year (late 2014). 1988 90 Td5 NAS soft top
2015 D90 XS SW |
29th Jan 2019 9:16am |
Back to the drawing board then! Think I will use rear wipe blank > 110 XS Double Cab
29th Jan 2019 10:12am |
