Home > Technical > DSC Fascia Switch. Where does it terminate?
hank
According to the below image '18' is the DSC switch. I have a blank fitted in this position so intend to use the circuit to switch an LED light bar (via relay)
So where does the feed terminate? Presumably I should find a plug somewhere in the engine bay?
 > 110 XS Double Cab
Post #754707 29th Jan 2019 8:33am
Martin
Site Admin
The DSC switch and wiring is only fitted on the Defenders with DSC, which is all of them from 2015 model year (late 2014).  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #754714 29th Jan 2019 9:16am
hank
Back to the drawing board then! Think I will use rear wipe blank > 110 XS Double Cab
Post #754719 29th Jan 2019 10:12am
