- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
27th Jan 2019 11:39am |
VVS210
Re: Puma Safari door lock barrel removal | |
1989964 wrote:Hi can anyone help me with removing the barrel within the lock of a puma safari door. I have looked and the guides all refer to the earlier lock which has a "pin" you must depress whilst inserting the key. My later lock does not have the pin and i dont have the key either. Im fitting a later door to my TD5 and the door didnt come with a key. It is a central locking model if that makes a difference.
Thanks.
Yes it does have the little pin to press in, you need to have a better look using a torch as its not immediately visible. Once you've found it you then need to use a right angled pick or a suitable Allen key to get to the pin & depress it. As LRA says though you'll probably need a key in it to be able to remove the barrel, although from memory I got the one out of mine by winding a small self tapping screw into the key slot & using a small pair of vice grips to pull it out thanks to the lock barrel being all gummed up!
27th Jan 2019 5:54pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
