Home > Puma (Tdci) > Puma gearbox selection problems after new clutch. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2414 |
Does the clutch pedal feel ok/air free?
As well there is a rubber gaiter at the bottom of the selector than can be jamming the movement. Unlikely though. Not sure if it possible to fit the friction plate the other way around. Puma 110" SW ............................................................. Earth first. Other planets later |
14th Oct 2018 11:40am |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 429 |
They may have tightened up the four bolts holding the gear selector in a little too tight. The manual state 25nm whilst in 3rd gear, but mine was less because the gear change was terrible. I think there is a service action to add a couple of extra bushes in to stand it all off a little. I'll see if I can find the info about it.
Click image to enlarge |
14th Oct 2018 2:32pm |
Oh and one other thing, I've seen a few peoples report on the ball/socket being an issue at the bottom of the gear stick. It gets a little rusty and can expand/crack the ball making the gear change pretty bad. Worth a check if you're going back in there.
14th Oct 2018 2:34pm |
Timbo66 Member Since: 14 Oct 2018 Location: Leicester Posts: 37 |
Thanks for the info guys.
The clutch itself is spot on. It bled well and has a good pedal. It's just the actual selection, it doesn't crunch to go into gear. I'll check the ball and nut torque settings. I'll also carry out the bush upgrade. Thanks again. Tim. |
14th Oct 2018 3:17pm |
This is the thread about the bushes. http://www.defender2.net/forum/topic29132.html
14th Oct 2018 3:21pm |
Cheers Ben
14th Oct 2018 9:15pm |
Hi Ben
Fitted the bush kit and was better. Now I’ve fitted a short shift kit and it’s perfect. Thanks all for the advice |
26th Jan 2019 3:39pm |
Glad to help mate! I’ll be honest I’ve not yet done either, they’re on the ever longer list of thing that are ‘next’.
26th Jan 2019 4:06pm |
I’d definitely fit the slick shift. Got the one from Syncro Gearboxes, really well made, but it’s made such a difference. Even the wife drives it now.
27th Jan 2019 11:01am |
Big Harold Member Since: 09 Jul 2018 Location: nsw Posts: 71 |
I found that when I did mine and went to replace the gear stick it was very stiff to select gears.
Finally worked out that the bush that the gear shift ball fits into is a slight snap fit therefore when fitting the gearshift it was not actually snapping over the ball more like resting on the bottom edge of the ball and applying upward pressure. I think I actually fitted the bush first to the ball then fitted the whole lot as an assembly fiddly but worked much better. Mark |
28th Jan 2019 10:07pm |
I found the same, also a tap on top of the gear lever helps to reseat the selector.
28th Jan 2019 10:38pm |
