Home > Puma (Tdci) > Puma gearbox selection problems after new clutch.
Timbo66
United Kingdom 2008 Defender 90 Puma 2.4 CSW Java Black
New to the forum and the land rover world.
I have a 2008 defender 90 with the 2.4 tdci engine and mt82 box. It had a really hard clutch pedal so along with a couple of mechanic friends we changed the clutch and concentric bearing.
However after refitting the box the gear selection is awful. First to second is ok but heading into third you end up in fifth. It's almost like there is no gate into third.
When you can find all of the gears it drives fine with no noises coming from the box. The area around the bottom of the gear lever where it connects to the ball socket feels notchy. It has all been well greased.
Any ideas???
Many thanks.
Post #734621 14th Oct 2018 7:48am
MK
Does the clutch pedal feel ok/air free?
As well there is a rubber gaiter at the bottom of the selector than can be jamming the movement. Unlikely though.
Not sure if it possible to fit the friction plate the other way around. Puma 110" SW
Post #734659 14th Oct 2018 11:40am
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
They may have tightened up the four bolts holding the gear selector in a little too tight. The manual state 25nm whilst in 3rd gear, but mine was less because the gear change was terrible. I think there is a service action to add a couple of extra bushes in to stand it all off a little. I'll see if I can find the info about it. Thumbs Up
Post #734689 14th Oct 2018 2:32pm
BenB8man
Oh and one other thing, I've seen a few peoples report on the ball/socket being an issue at the bottom of the gear stick. It gets a little rusty and can expand/crack the ball making the gear change pretty bad. Worth a check if you're going back in there. Rolling Eyes
Post #734690 14th Oct 2018 2:34pm
Timbo66
Thanks for the info guys.
The clutch itself is spot on. It bled well and has a good pedal. It's just the actual selection, it doesn't crunch to go into gear.
I'll check the ball and nut torque settings. I'll also carry out the bush upgrade.
Thanks again.
Tim.
Post #734694 14th Oct 2018 3:17pm
BenB8man
This is the thread about the bushes. http://www.defender2.net/forum/topic29132.html Thumbs Up
Post #734695 14th Oct 2018 3:21pm
Timbo66
Cheers Ben Thumbs Up
Post #734748 14th Oct 2018 9:15pm
Timbo66
Hi Ben
Fitted the bush kit and was better. Now I’ve fitted a short shift kit and it’s perfect.
Thanks all for the advice
Post #754086 26th Jan 2019 3:39pm
BenB8man
Glad to help mate! I’ll be honest I’ve not yet done either, they’re on the ever longer list of thing that are ‘next’.
Post #754090 26th Jan 2019 4:06pm
Timbo66
I’d definitely fit the slick shift. Got the one from Syncro Gearboxes, really well made, but it’s made such a difference. Even the wife drives it now.
Post #754261 27th Jan 2019 11:01am
Big Harold
Australia 2015 Defender 130 Puma 2.2 HCPU Alpine White
I found that when I did mine and went to replace the gear stick it was very stiff to select gears.
Finally worked out that the bush that the gear shift ball fits into is a slight snap fit therefore when fitting the gearshift it was not actually snapping over the ball more like resting on the bottom edge of the ball and applying upward pressure.
I think I actually fitted the bush first to the ball then fitted the whole lot as an assembly fiddly but worked much better.
Mark
Post #754660 28th Jan 2019 10:07pm
Timbo66
I found the same, also a tap on top of the gear lever helps to reseat the selector.
Post #754668 28th Jan 2019 10:38pm
