![]() | Home > Puma (Tdci) > Puma 130 rear diff |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3656 ![]() ![]() ![]() |
are you sure its not the rear prop shaft? DEFENDER 90 TDCI XS,
Mack Member Since: 11 Jan 2014 Location: Central America Posts: 58 ![]() ![]() |
Not sure how to check it
Moneypit Member Since: 27 Feb 2018 Location: North Yorkshire Posts: 271 ![]() ![]() |
If you decided to go for a diff rebuild then Xcess4x4 is the company I'd suggest
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17609 ![]() ![]() ![]() |
You'd need the 4-gear P38 diff which was used on the more powerful P38s and is harder to find. The 2-gear (commonplace) one will fit but not last long. You could use one as the basis of an ATB or Airlocker build though.
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
The rear diffs are a bit of a weak point, seen a few go whereas the old Salisbury went on and on.
To be honest if I was in the UK I would get a diff built up by either Ashcroft or Xcess and exchange it. Good time to add something like an ATB to the order and make it really worth doing ![]() If I had a noisy one I wouldn't bother trying to do a DIY refurb to be honest. You need several special tools to do it properly so unless you have a very well equipped garage it is better left to those with the tools. --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
It's not hard to overhaul a diff properly but it isn't a job for a novice.
