Home > Puma (Tdci) > Puma 130 rear diff
Mack
2008 Defender 130 Puma 2.4 HCPU Chawton White
Puma 130 rear diff
Hi all, cheers
The rear differential in my '08 spec 130 is vibrating excessively, randomly. Sometimes it vibrates alot making vibration noises but most of the time behaves normally, everything works fine. Expecting the worse, how true is it that the rear diff in 130's from those years is the same as in p38 range rovers? from which years? Scrapyards are loaded with them here so it would probably be an easy and cheap swap, being this possible of course! 2nd thought, being lucky enough it just needs bearings, which are the best I can buy online, is there some sort of kit? 3rd scenario which are the differential possible upgrades just in case I need a full replacement? It has 274k km on the clock, oil changed every 4 motor oil changes or so, only had one oil leak fixed under warranty other than that, the diff has never been opened. shaft checked etc
Thanks in advance for the help
Mack
Post #752522 19th Jan 2019 10:53pm
LR90XS2011
are you sure its not the rear prop shaft? DEFENDER 90 TDCI XS,
Post #752536 20th Jan 2019 6:12am
Mack
Not sure how to check it Whistle I checked all the bolts and all are in place and tight greased every week
Post #753896 25th Jan 2019 3:17pm
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
If you decided to go for a diff rebuild then Xcess4x4 is the company I'd suggest
Post #753911 25th Jan 2019 5:15pm
You'd need the 4-gear P38 diff which was used on the more powerful P38s and is harder to find. The 2-gear (commonplace) one will fit but not last long. You could use one as the basis of an ATB or Airlocker build though.
Post #753922 25th Jan 2019 6:22pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
The rear diffs are a bit of a weak point, seen a few go whereas the old Salisbury went on and on.
To be honest if I was in the UK I would get a diff built up by either Ashcroft or Xcess and exchange it. Good time to add something like an ATB to the order and make it really worth doing Thumbs Up
If I had a noisy one I wouldn't bother trying to do a DIY refurb to be honest. You need several special tools to do it properly so unless you have a very well equipped garage it is better left to those with the tools. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #753943 25th Jan 2019 8:05pm
It's not hard to overhaul a diff properly but it isn't a job for a novice.
Post #753945 25th Jan 2019 8:10pm
