Home > Puma (Tdci) > Clutch switch
Jonnyfive
England 2011 Defender 90 Puma 2.4 X-Tech LE Zambezi Silver
Clutch switch
I’ve got a replacement clutch switch, will I need to bleed the clutch after putting new one on?
Post #740945 17th Nov 2018 1:07pm
landy andy
No.
Post #740949 17th Nov 2018 1:25pm
Jonnyfive
Thanks
Post #740953 17th Nov 2018 2:28pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Retrieving this topic... Been having that problem, engine revs go up as I engage clutch between gears...
After reading some posts trying to sort the problem I believe it's the clutch switch... Have a new one already to replace...
Reading landy andy reply saying it's not necessary to bleed the circuit, I have a doubt: Is this (pic below) supposed to be normal? I have flui on the switch? Despite this, it's not necessary to bleed the circuit? should there be fluid on the switch?
 Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #753639 24th Jan 2019 2:22pm
Jonnyfive
I did not see any on the electric side of things when I replaced my switch and you don’t need to bleed the clutch.
Post #753711 24th Jan 2019 7:14pm
Shouldn't be clutch fluid on that plug and socket, you might find that is the issue you've had with it and not the clutch switch it's self.
As it stands it's probably shorting the contacts and or causing all sorts of issues.
I would clean and completely dry all contacts and plug bad socket. You may find it's cured even without the new part.
Worth trying...
Seems to me like someone may have disconnected the switch, spilt clutch fluid over it with a top up.
And instead of, cleaning and drying it before reconnecting it they shoved it back on and hoped no one would notice! Rolling Eyes
Another option is just bridge the clutch switch instead... But that's personal choice and to do so you'd need 2pole J.P.T. Connectors, and bridge the female LR plug.
I run mine bridged all the time and much prefer it. $W33T $0U7H3RN $UG4R
Post #753717 24th Jan 2019 7:43pm
lrmaniac
as far as I'm aware the clutch fluid hasn't been toped up, or opened...
but I'll try to clean it and plug it again...it's worth trying...
If I bridge the circuit and it works, means that the switch is ok?
I've had the circuit bridged once, but don't like it... great to drive, but too much stress on the diff and transmission, too much clunks and bangs Very Happy Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #753753 24th Jan 2019 9:04pm
If you want the clutch switch then it’ll need replacing. But try cleaning it up a bit first as mentioned and dry.
You shouldn’t have any issues with it if it was bridged with the trans, if you do then there would be excess play in the drivetrain. I found that with worn DM’s and prop UJ’s.
But, everyone to their own and how they’d like it. Thumbs Up $W33T $0U7H3RN $UG4R
Post #753761 24th Jan 2019 9:17pm
