Home > Puma (Tdci) > FORScan OBDII scanner works on PUMA 2.4 TDCI
Page 3 of 5 <12345>
MK
Just by looking I dont think you can tell if you have an out of range or leaky injector.
A pilot calibration can fail because of many factors, one of them being faulty injector. I can probably say that sometimes a failed pilot correction can lead to white smoke. High maf, low map and egr figures can also contribute. Im talking by personal experience. Im not a specialist. Puma 110" SW
Post #753437 23rd Jan 2019 6:50pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Again, whilst you've got them out you may as well get them tested. It's cheap enough and you can't really tell by looking.
As components wear they can become a little out of sync, the pump re-learn and pilot correction can help and cure a faint knock from my personal (non-professional) experience.
A faulty VCV can cause issues too. Again fairly cheap to replace. If your idle isn't steady (as it it jumps up and down a bit) I'd go for VCV being faulty if the injectors turn out to be ok. Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #753455 23rd Jan 2019 7:47pm
Tomotomo
I have been quoted 125 quid to bench test them. Is that about fair?
The cynic in me is telling me they will turn around and say they are all knackered. Whistle Laughing
Guess I should get a print out?
Post #753596 24th Jan 2019 12:02pm
MK
I had the same problem. I had to spend some time looking for a shop that would not just wanted to sell me new injectors. Puma 110" SW
Post #753600 24th Jan 2019 12:09pm
Tomotomo
Are they supposed to come out dripping in oil?
I have two out now. Two to go.
I pulled the connectors off the injectors one by one while it was running. No 1 cylinder made hardly any change.
No 2 a little
No 3 the biggest change
No 4 a little.
So I am guessing no 3 is my healthiest
Cylinder/ injector
Neutral
Post #753618 24th Jan 2019 12:59pm
MK
All normal. When refitting make sure the injector seat on the head is clean. Puma 110" SW
Post #753621 24th Jan 2019 1:08pm
Tomotomo
Ok they are in for testing should find out tomorrow. Tried to clean the head where the injector goes. I don't have a seat cutter. What else could I use ? A clean cloth and a flat head screw driver? Is it ok to spray some brake cleaner down there to loosen the oil and carbon?
I will do an oil change when it's back together.
I have taken the rocker cover off and changed the gasket.
Can't see any copper washers on the head. Just on the end of the injectors. They look unworn. I will change them anyway.
Post #753704 24th Jan 2019 6:48pm
MK
For cleaning I use a cloth wrapped around the same thin and long bolt used for the inj. clamps. The idea is to remove debris, soot particles, etc. I would not spray anything. Yo do need to change the washers as they get flattened once used. Puma 110" SW
Post #753733 24th Jan 2019 8:39pm
ozzie1989
As suggested if you can get away with it use a cloth on something long, preferably round ended tool.
If the seats are really bad you'd need a seat cutter but be careful, I bought a cheap one thinking it wouldn't be that good. It didn't seem that sharp. Didn't push down on it or anything but by gosh the head is soft, turned once and it seemed to take of all the crud and some metal.
Let us know how you get on with the injectors... I thought that price was a bit steep though to be honest Whistle
Forgot to say, as you're not refitting them straight away as long as what you spray will evaporate I can't see it doing any harm, but again I'm not an expert Thumbs Up Now: 2010 2.4 TDCi 110 Utility Wagon
Post #753794 24th Jan 2019 10:53pm
Tomotomo
injector results.....
Well surprise surprise they all failed. Big Cry Banging Head Censored
I am not sure I entirely trust the diagnosis.
But i cant really make head nor tail of the results.
Any help deciphering the following would be great.
Bow down
Post #753842 25th Jan 2019 11:27am
MK
TBH I do not know what it means. You can ask the shop what is the problem: leak, full load, return, preinjection, emissions. Those are the parameters I know. I hope somebody with more knowledge can help. Worse case scenario you can get new ones at 150 quid ea from a forum member.
If the issues are the nozzles then you can have them exchanged. They are sold as spares. Puma 110" SW
Post #753846 25th Jan 2019 11:42am
ozzie1989
Hmm, I'm no expert either.
What I can see though is that on page 2 injectors 1,2,3 were out of range of 'normal values' and on page 3 injector 4 was out of range.
Also on page 2 a temperature reading was slightly high.
Perhaps take the sheets to another garage and ask their opinion on the results? Knowing that you'd removed the injectors yourself I would have thought they'd have guessed you wouldn't be buying new ones from them and as such wouldn't have biased the results?
Let us know how you get on Thumbs Up Now: 2010 2.4 TDCi 110 Utility Wagon
Post #753918 25th Jan 2019 6:03pm
Tomotomo
Thanks for the advice.
Yes I noticed the temp was above the set point.
I wonder if that's the way they can manipulate the results?
Problem I have is I guess I will never know.
The tester said that no 4 injector was the most worrying as it had practically no pilot .01
And i think the last page is leak off amounts and it had the highest.
So logic should say that no 4 was causing the misfire at idle.
But as none off them leaked in 1st test if I am reading it right, that wouldn't explain the extra grey smoke I get when it's starting from cold.
Feeling a bit down as know i am thinking it could be compression related as that typically improves as an engine warms...
Problem is you can't compression test with the fuel pump on ?
Maybe I should just bite the bullet buy 4 new injectors.
Coul
Post #754027 26th Jan 2019 11:15am
ozzie1989
Unless you're willing to hand it over to a transit specialist, or get the injectors re-tested I think you're right, change the injectors and see what happens. It is a rather expensive leap of faith to take though...
Out of interest, how bad is the misfire at idle? Do you have a video of it? Now: 2010 2.4 TDCi 110 Utility Wagon
Post #754030 26th Jan 2019 11:20am
4wd-junky
Grey smoke at cold start could also be caused by the EGR valve.
I'm reading with interest, but as you've discovered we're all out of our depth on this one ….. I'd be looking for a transit expert that you can trust.
Post #754063 26th Jan 2019 1:45pm
Page 3 of 5 <12345>
