Home > Puma (Tdci) > Odd droning and propshaft clonk?
NoDo$h
After the seized wheel bearing last week, I finally persuaded Mrs Do$h to turn off the mindless crap pouring out of our local radio station and actually listen for mechanical noises today.
Wish I hadn't Rolling Eyes
Heard what sounded like a wheel bearing drone from NSF but jacking the car showed no play in the bearing. Knocked the transfer box into neutral and rotated the wheel and got a momentary stiffness at the same point on every rotation of the propshaft (NOT the wheel).
Got underneath to see if I could work out where it was coming from. UJs seem a little dry, but otherwise ok. I couldn't work out if the stiffness was in the UJs, the transfer box or the front diff as both the diff and the transfer box gave a slight clonk as the stiffness was overcome (just taking up the slack I suspect). To help get a clearer idea I dropped the NSF and jacked the OSF instead. Again, no play on the bearing but on this side I got no momentary stiffness in the propshaft.
Thoughts?
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #75280 10th Jun 2011 7:53pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
A momentary stiffness at your age Isn't too bad Original Member Pie n Pea Club.
110 HCPU Tipper
Post #75295 10th Jun 2011 10:03pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
did you check both ends of the prop? BM52
Post #75296 10th Jun 2011 10:21pm
BigMike
Are you running standard suspension or something else?
If you drive in first just using the anti stall and go lock to lock can you hear anything ?
Post #75306 11th Jun 2011 6:32am
NoDo$h
Both ends of the front propshaft checked - it feels like it's the rear end UJ on the front prop, but puzzled why it only did it when the OSF was up and didn't do it when the NSF was jacked. Really need to get the whole front end up to check. Will check the grease nipple on the UJs while I'm at it.
Will take it out in the field and try the lock - to - lock on anti-stall too Thumbs Up
2008 D3 SE
2010 90 XS SW
2006 D3 SE - gone
Post #75321 11th Jun 2011 8:08am
BigMike
there isnt a grease nipple on the UJs
Post #75322 11th Jun 2011 8:10am
NoDo$h
Mine's an 07 - should have three neeps per propshaft. Middle of the shaft and one at each end on the UJ
2008 D3 SE
2010 90 XS SW
2006 D3 SE - gone
Post #75325 11th Jun 2011 8:12am
mse
Have you got the greese nipples - they caused similar problems and would work loose - hence the change and the service action if people had problems = new prop shafts without nipples! Mike
Post #75329 11th Jun 2011 8:20am
NoDo$h
I'll let you know my nipple count after I demolish this huge pile of home-cured bacon with fried goose egg, before I take a dump, then I need to finish rattling the papers while downing my third cuppa. THEN the day's work can begin. Mr. Green Getting up at 06:00 to feed the animals doesn't count as work in this house - it's food preparation Whistle
All good advice/suggestions so far folks, keep them coming Thumbs Up
2008 D3 SE
2010 90 XS SW
2006 D3 SE - gone
Post #75332 11th Jun 2011 8:25am
Grockle
the uj's have grease nipples, on later and replacement shafts which had to be chaged because the nipples fell out dont have grease nipples on the slidding joint as on original ones 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #75335 11th Jun 2011 8:37am
MK
IMHO a non greasable propshaft should not be for a 4x4 vehichle which is intented to cross "wet" sections. I grease all UJ`s every 5000 km. Takes 5 min and GBP 5.
Sliding joints work better with MOS2 grease, UJ use normal greas. Puma 110" SW
Post #75351 11th Jun 2011 9:30am
BigMike
No grease nipples on mine. As mh does, I grease them but every couple if thisand miles. Takes minutes
Post #75355 11th Jun 2011 9:45am
RED-DOT
Like most trucks now the deletion of grease nipples is to cut down on servicing time and they are sealed for life, just they don't live as long now. My Puma got a new front propshaft as there was a service bulletin to replace any shafts that customers complained about... makes you wonder what kind of PDI they get if they don't notice the nipples missing. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #75356 11th Jun 2011 11:12am
NoDo$h
Rear propshaft fine - centre grease nipple and both UJ nipples present and correct.
Front propshaft not good. - holes where the UJ nipples should be. Will post some pics later.
Guess I'll be talking to the dealer on Monday about a new propshaft quoting SSM40851 Whistle
Thanks folks Mr. Green
2008 D3 SE
2010 90 XS SW
2006 D3 SE - gone
Post #75376 11th Jun 2011 4:54pm
RED-DOT
No argument there.. i had mine replaced. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #75377 11th Jun 2011 4:56pm
