Home > Maintenance & Modifications > Glwyn Lewis
arran jones
Glwyn Lewis
Hi all...
As some may know...i hav some glwyn lewis shields
Back of front wheel & front of back wheels
Just a brief Q about there rear ones...when you screw them in with the steel screws provided into the aluminium tub....has anyone had corrosion problems with the steel-allu
There is some special grease provided....does this do the job!??
Thx in advance Thumbs Up
Post #751304 14th Jan 2019 9:18pm
landy andy
I covered all my items, and the tub with Dintitrol, loading them up as I fixed them to seal the items together.
Post #751308 14th Jan 2019 9:38pm
Yes, use the grease. That's a dissimilar metal corrosion inhibitor / block and also should be anti seize.
Apply is to all threads and or alloy to Stainless mating surfaces if present.
Disposable gloves are useful too, it can be hard to get off and get everywhere.
On a similar subject, have yiu considered a Nakatanenga Stainless bolt kit for the whole 90? Thumbs Up KEEP CALM AND Drill ON
Post #751311 14th Jan 2019 9:46pm
arran jones
Thanks both
Custom90...no i haven't considered that as yet!
Post #751370 15th Jan 2019 8:30am
WindyJ
At the risk of being a thread hijacker....I have some Glwyn Lewis kit to fit which I inherited from prev owner. It’s a drop link removal kit with sumo bar. What will this actually do? Is it worth fitting when I do mainly road and towing with a bit of towing horseboxes across fields in summertime. Advice welcomed!
Post #751430 15th Jan 2019 12:53pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
I've got quite a bit of Gwyn Lewis kit fitted and his garage services my Land Rover.
He's very approachable and helpful.
Some of his products are for road going vehicles and some are for Challenge type competition vehicles.
Why not contact him directly and get the answer straight from the designer and manufacturer of the kit?
Post #751455 15th Jan 2019 2:47pm
WindyJ
Did actually drop them an email before Christmas but not heard back, dont like to push as i’m not the customer so to speak. Didn’t realise they were a garage though, thats good as i can pop in next time i’m over in Oswestry...not too far detour.
Post #751459 15th Jan 2019 3:00pm
landy andy
Unless you need to swap the track rod end that is at the end of the drop link, i wouldn’t bother doing the swap for your listed use. It’s also a bit of a pig of a job, as to get the old drop arm off is not simple normally.
I would suggest listing on here and getting some money for it.
Post #751496 15th Jan 2019 5:48pm
arran jones
Once these guards are fitted...
Will they need to be taken back off for when i do rust treatment for the chassis?
Post #752683 20th Jan 2019 8:20pm
landy andy
Then I wouldn’t apply the grease. It’s either a waste, or just creating work to remove it. Just get the rust treatment under the brackets now, so only the shields need to be removed.
Well that’s my plan anyway.
Post #752685 20th Jan 2019 8:30pm
arran jones
Cool thanks...
The front sheilds dont need the grease as much though i guess...as it gets bolted into the wheel arch insides anyway
Post #752689 20th Jan 2019 8:43pm
jst
It changes the drop arm off the box to accept a track rod end rather than the normal defender ball joint. I fit them to off road vehicles but not the road going towing defenders I have.
As above can be a pain to change the drop arms over.
Not worth fitting unless you have issue with drop arm ball joint.
I would be interested if you were looking to sell. They are worth a bit. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #752864 21st Jan 2019 7:14pm
