![]() | Home > Technical > Mapt pigtail plug |
Dieseljock Member Since: 03 Jun 2017 Location: Inverclyde Posts: 32 ![]() ![]() ![]() |
Have a look on simtek motorsports site or give them a call. We’ve used them for lots of unusual pugs for tractors and plant machinery, where the manufacturers would only supply a complete loom
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2533 ![]() ![]() ![]() |
Looks similar to plugs fitted to my John Deere tractor. Maybe your local John Deere dealer can help. Defender 90XS SW
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2450 ![]() ![]() ![]() |
Cheers for that! Puma 110" SW
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
Don’t forget PaulMc on here...
No entiendo Puma 110" SW
PaulMc supplies and identifies connectors
![]() ............................................................. Earth first. Other planets later |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 504 ![]() ![]() ![]() |
The TMAP connector is C1588 (YPC903490)
It's a Yazaki connector that's not available through Land Rover. It is available as a 'pigtail' through Ford Motorcraft (in the US), as WPT-205 - ![]() It can be sourced from Ford specialists. Here are a few that I found - https://www.bmotorsports.com/shop/product_...jacuqmvta0 https://www.efihardware.com/products/2142/...sor-Female http://www.nzefi.com/product/ford-falcon-a...connector/ . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' Last edited by PaulMc on 19th Jan 2019 4:08pm. Edited 1 time in total |
Thanks so much Puma 110" SW
