Home > Maintenance & Modifications > Suspension lift - am I missing the point?!
Page 2 of 3 <123>
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
landy andy wrote:
A lift gives you articulation.
And so more off road traction and stability.
Love the articulation on that! And those rims look great. Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #751636 16th Jan 2019 9:53am
Markez79
Would Gywn Lewis Spring Spacers be an option for what I'm after? i.e. a bit of additional lift without the need to alter the suspension set up etc?
Thanks
Post #751702 16th Jan 2019 2:45pm
camelman
I'm.running gywn Lewis 2 inch spacers and shock drop plates. Much cheaper way of achieving 2 inch lift and keeping original articulation
Post #751735 16th Jan 2019 5:39pm
Thanks
Mark, you may find that 30mm wheel spacers (which will effectively make your Boosts 0mm offset) solve your rubbing problems. Where do they rub at the moment, and under what circumstances?
Post #751738 16th Jan 2019 5:44pm
Adam17
That's a tidy looking Defender..
I wouldn't mind a roll cage myself, but need a slightly fatter wallet first Laughing Regards
Adam
Loving The Duchess
Post #751850 17th Jan 2019 9:58am
benniferj
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
I don't think they'd fit without a lift Laughing
Funnily enough just bought a 110 and its standard height on 265... drives absolutely incredibly compared to the 90... lets put it this way I'm not lifting the 110 at all. But then I'm not pay and playing it either!!!
Post #752053 18th Jan 2019 9:23am
Adam17
That looks tidy.
Really need to find some green laning buddies near me.
And more importantly, some green lanes lol.
Not fond of the idea of taking my daily to a pay n play and wrecking it hahah Regards
Adam
Loving The Duchess
Post #752061 18th Jan 2019 9:49am
MetalMatt
United Kingdom 1989 Defender 90 300 Tdi HT Baltic Blue
This is how i am wanting to get my 90 to look like now it has just been fully rebuilt.... Hope you dont mind me asking, What off set rims have you got and what size tyres are they and also where did you get your cage from as i kinda like that alot Thumbs Up Thumbs Up
As you can see i need more rubber to fill my arches out Razz
 1995 Land Rover Discovery 300tdi - Sold
1989 Land Rover 90 - Rebuilding/built - its a project
2002 Land Rover Discovery TD5 - Sold
2017 Mini JCW F56 - Current Daily Driver
Post #752075 18th Jan 2019 10:37am
Adam17
That's a lovely Blue!! Regards
Adam
Loving The Duchess
Post #752086 18th Jan 2019 11:14am
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
I always try and dissuade folk from lifting vehicles unless wanting to run bigger tyres than 33in- all you end up with is a vehicle that drives worse on the road for minimal benefit off it. for most folk its all about the look, rather than the functionality.
A lift does not necessarily give you articulation- the limiting factor in this case is the length of the damper and limitations of the A-frame ball joint and the dislocation cones.
As regards 255/85/16s they *should* fit at standard height so long as your springs are not tired with minimal rubbing. If you are running boosts you will probably need spacers to achieve this.
Chris
Post #752092 18th Jan 2019 12:02pm
redline
Switzerland
Its a matter of degree though - not all lifted vehicles drive worse than stock.
I'm running a 35mm lift on my 110, and it objectively drives better than it did stock under almost all conditions (on road, off road, loaded, etc...).
Obviously if you go to extremes, there will be compromises though. Its a matter of really determining your needs, and choosing the appropriate set-up to best meet them.
Post #752158 18th Jan 2019 4:37pm
landy andy
Agree with you redline. That 90 of mine drove better than my Tdci did on standard suspension setup and anti rollbars.
I’m very against bolting some pooy Britpart or Terrafirma lift to a vehicle, but done with proper kit, it can give you all. Articulation, road manners, and reliability. I would happily fit the kit that I had on the 90 to any vehicle I have.
Post #752207 18th Jan 2019 7:42pm
Markez79
Hi Landy Andy,
Would you mind providing details of the kit you fitted to achieve this?
Thanks
Mark
Post #765456 26th Mar 2019 12:17pm
landy andy
Gwynn Lewis kit. Many like terriblefirma have copied it, but his is brilliant, and has been well tested in competitions.
It drove better than standard new Defender on road and was fantastic off road even when fully loaded with roof tent. When off road it was so stable as you didn’t really get to the point when it lurched from one side to the other due to be crossaxled.
You just always knew how the vehicle would handle, never gave you a shock or fright.
Andy.
Post #765460 26th Mar 2019 12:26pm
Markez79
Sounds good......stupid question, but I assume a similar result on a 110...?
Thanks again
Post #765463 26th Mar 2019 12:34pm
Page 2 of 3 <123>
