Home > Puma (Tdci) > 2.2 ticking when cold
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Ciao,
I have had a search and found a few things on the 2.4 but nothing regarding the 2.2 engine.
Basically, now it’s getting cold, I get a ticking noise when I first start, it lasts about 5 minutes until the engine is warm then it’s gone.
It makes the same sort of noise as if there was a stone in the tyre, not quite as loud but that sort of tick.
Any ideas?
Jan
Post #741421 20th Nov 2018 10:19am
Roy5695
Have you checked around the injectors for any signs of leaking. Could be the injector seals worn or the clamp bolt slightly stretched and loose until it warms up.
There’s also various heat shields and brackets on the back of the engine that have been known to come loose or crack. Worth giving these a check over too. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #741441 20th Nov 2018 12:29pm
Yannis
I have checked all around the injectors and there is no signs of movement or a leak.
It’s most noticeable when it’s been really cold overnight. I will try and have a better listen from where it’s coming from but it almost seems low down at the back of the engine. I will try and get under it and have a look at the heat shields as suggested.
I have just replaced the oil but this didn’t change anything.
Could it be a bad hydraulic lifter?
Your thoughts appreciated.
Post #751675 16th Jan 2019 12:19pm
M94PUMA
Doesn’t sound like this does it?
Or Definitely engine??
I had another noise similar the other day it was one of the idler pulleys had gone, simple 5 minute job of removing the fan belt and just unbolting the old pulley and bolting a new one on,
Post #751728 16th Jan 2019 4:54pm
Yannis
Definitely engine.
It sounds like the ticking you get when you have a stone in the tyre, but instead of changing the frequency with speed, it changes with RPM..?
Post #751754 16th Jan 2019 6:23pm
Yannis
Just a note, when it’s cold, the ticking noise is accompanied with the engine hunting about 50rpm up and down?
Post #759405 18th Feb 2019 2:15pm
JOE_130
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Java Black
Has it been re-mapped? If so who did it?
Post #759564 19th Feb 2019 11:55am
Yannis
Yes, 170 by BAS with intercooler
Post #759573 19th Feb 2019 12:51pm
JOE_130
Just wondering - mine makes exactly the same noise (I suspect) as the description matches and I have an Alive remap. It only does it very rarely though even when cold. Not particularly happy with the map so going to go back to standard - will see if the problem follows the cal.
Post #759589 19th Feb 2019 2:17pm
Yannis
I have my original ECU so I can just swap it out.
Will give it a go and see if the noise changes at all.
Post #759594 19th Feb 2019 2:58pm
ozrob
Australia 2013 Defender 110 Puma 2.2 SW Baltic Blue
Yes mine has a noise only when cold BAS 150 remap, I notice it when cold till the engine warms up, a bit like a light knocking sound, that increases with engine RPM, I am thinking it is the BAS tune settings for when the engine is cold.
How did you go with fitting the original ECU and the noise?
Post #769199 19th Apr 2019 12:40pm
UtilityTruck
I get this on my unmapped engine. Worse when it’s cold ambient temp, most noticeable on cold start but I think there all the time.
Any tips on checking the injectors over, or anything else to check?
Same as Yannis, noise increases frequency with RPM and is definitely a ticking/tapping noise. 2014 Keswick Utility 2.2
Post #812604 29th Jan 2020 10:11pm
Stuarth91
Scotland 2015 Defender 110 Puma 2.2 USW Santorini Black
I get this too on a 2015 2.2. Mine hasn't been remapped either.
Post #824331 9th Apr 2020 6:46pm
keith
Exactly the same noise when cold with me also. Bas 170 remap.
2.2
Keith
Post #824342 9th Apr 2020 8:22pm
Sulisuli
I had the same problem on my 2015 tdci ticking noise that was there from cold and continues even when warm, remapped stage 2 engine, the outcome wasn’t great I’m sorry to say Shocked 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #824347 9th Apr 2020 9:16pm
