Home > My Defender > 110 300tdi CSW ReBuild |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 817 |
And Santa came early....smart Santa knew I'd like some Gwyn Lewis and YRM parts...
Click image to enlarge Click image to enlarge Click image to enlarge |
22nd Dec 2018 1:13pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5150 |
Not bad that at all looks like a garage has replaced the chassis hence the rusty parts.
Good stuff on getting a stack of parts. One thing though is if a job is going really well and your getting bored of it, stop. Move onto something else, that way you will return to it on a mental high. Same thing if things are going well and then they start to go off, stop and pack up. Come back at it again the next day. Saves you smashing stuff Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
22nd Dec 2018 5:09pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10733 |
Santa must have been in the know nidge
Nice lot of parts to put back on now when the time is right 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
22nd Dec 2018 8:15pm |
Yes Clayton I sent him a list
22nd Dec 2018 8:20pm |
That's one way to make sure you get what you want 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
22nd Dec 2018 10:12pm |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
So many shinies are the cappings staying galv? Would look good against the bodywork 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
23rd Dec 2018 3:51am |
Yes Mash I agree, plan is to keep the cappings, rock sliders and rear corner cappings in the galvanise finish, undecided about the bulkhead yet .
23rd Dec 2018 8:38am |
Made some good progress over the Christmas break, working outside is always more pleasant when the weather is dry and mild.
Got the axle and suspension parts all stripped down and painted, 2 coats of Corroless chassis in one, its a good product and on first impression its a far superior product to the POR15 which I used on the last build. Time will tell tho. Also decided on installing super pro bushes all round , just waiting on axle parts now springs shox etc.. Click image to enlarge Click image to enlarge |
31st Dec 2018 3:17pm |
The bad news is I found more rot, front of the rear tub, battery box, so another order gone into the good people at YRM have most of it cut out now and prepped for the new parts.
Click image to enlarge And the sills and Door posts are rotten too, looked Ok on first inspection but once I went poking with the screwdriver.....thats a big expense I hadn't counted on and will probable look out for a full set of galvanised ones. |
31st Dec 2018 3:26pm |
Nice progress there Nidge shame about the extra rot found, but at least it will be done and you will know it will last 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
31st Dec 2018 8:51pm |
Bit of an update, seat box rebuilt with new YRM battery box, under seat tool box and new end sections. purchased an air riveter which made light work of the job and the fit of the YRM parts was first class.
Click image to enlarge Also installed the new tub section and under tub support rail, just the new floor sections to make up now and then be ready for etch primer and paint. Click image to enlarge Click image to enlarge |
15th Jan 2019 9:10pm |
Great progress 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
15th Jan 2019 9:17pm |
Galvanized Cappings fitted and as new set of Puma station wagon rear springs on Gwyn Lewis galvanized hardware.
Click image to enlarge Click image to enlarge Biggest stumbling block for me now is the B-posts and sills, so if anyone knows of a good set about please let me know. Nidge. |
15th Jan 2019 9:23pm |
Galv cappings look awesome 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
15th Jan 2019 9:31pm |
