Home > Puma (Tdci) > Fusebox main feed cover
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Please could someone advise how to get the protective cover of the main feed terminal at the back of the drivers seat fusebox?
I want to put another connection on to it.
Thanks
Post #750733 12th Jan 2019 4:45pm
dorsetsmith
do you mean the one right Question 2.4
Post #750756 12th Jan 2019 6:03pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
I had this fight earlier. In the end I undid the 3 10mm bolts lifting the whole panel up enough to see the cover better. Two prongs need pushing inwards and sliding towards the drivers door. 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #750762 12th Jan 2019 6:37pm
Scotm
Dorset - Mine is different from the photo.
Rosco - I tried that as well but it looked like the was part of the fuse box in the way? Any further tips?!
Post #750763 12th Jan 2019 6:42pm
dorsetsmith
Mine is different from the photo. 2.2 under seat fuse box then
Post #750766 12th Jan 2019 6:55pm
Rosco
A little bit of brute force.
Dorset they are very different looking 2007 - Stornoway Grey 90 XS SW - Gone
Post #750768 12th Jan 2019 6:59pm
Scotm
Yep.
It is the lump of plastic at the front of this photo borrowed from eBay:
Post #750769 12th Jan 2019 7:00pm
Scotm
I found a better picture of the cover. Anyone know what to do with it to remove without breaking?
The picture I posted above looks like it has bits broken of it.
Post #751191 14th Jan 2019 1:28pm
Rosco
Thats exactly as mine looked, so I dont think yours has anything missing.
The clip running left/right needs pushing in, and there is the same on the back also. They are stiff and fiddly to come off, and I suspect they may even be a one time use item, but mine has slide back on no problem.
The pegs at the bottom are the slide guides 2007 - Stornoway Grey 90 XS SW - Gone
Post #751196 14th Jan 2019 1:55pm
Scotm
Thanks will give that a try at the weekend.
Post #751198 14th Jan 2019 2:25pm
qwert
2015 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Did you try?
Post #753378 23rd Jan 2019 3:29pm
Scotm
I did indeed!
Basic Instruction:
Loosen battery main positive terminal
Switch ignition on and off
Within 15 sec remove main battery positive terminal.
Undo the three bolts holding the fuse box in place.
Lift up the fuse box so you get better access to the terminal
Insert a short flat blade jewelers type screw driver under the pin in the direction of the red arrow for both the top and bottom pin (bottom not visible in photo) .
Slide the cover off in the direction of the yellow item.
Post #753410 23rd Jan 2019 4:49pm
qwert
Thank you Scott for a valuable tip!
Post #754743 29th Jan 2019 11:48am
I'd have thought that conduit should go to under that plastic cover under that brown cable.
That is leaving that section of cable more lulnerable than it should need to be for no valid reason. $W33T $0U7H3RN $UG4R
Post #754811 29th Jan 2019 5:00pm
