![]() | Home > Puma (Tdci) > Fusebox main feed cover |
do you mean the one right
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1867 ![]() ![]() ![]() |
I had this fight earlier. In the end I undid the 3 10mm bolts lifting the whole panel up enough to see the cover better. Two prongs need pushing inwards and sliding towards the drivers door. 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 675 ![]() ![]() ![]() |
Dorset - Mine is different from the photo.
Rosco - I tried that as well but it looked like the was part of the fuse box in the way? Any further tips?! |
Mine is different from the photo. 2.2 under seat fuse box then
A little bit of brute force.
Dorset they are very different looking 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Yep.
It is the lump of plastic at the front of this photo borrowed from eBay: ![]() Click image to enlarge |
I found a better picture of the cover. Anyone know what to do with it to remove without breaking?
The picture I posted above looks like it has bits broken of it. ![]() Click image to enlarge |
Thats exactly as mine looked, so I dont think yours has anything missing.
The clip running left/right needs pushing in, and there is the same on the back also. They are stiff and fiddly to come off, and I suspect they may even be a one time use item, but mine has slide back on no problem. The pegs at the bottom are the slide guides 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Thanks will give that a try at the weekend.
qwert Member Since: 26 Aug 2010 Location: Switzerland Posts: 33 ![]() ![]() |
Did you try?
I did indeed!
Basic Instruction: Loosen battery main positive terminal Switch ignition on and off Within 15 sec remove main battery positive terminal. Undo the three bolts holding the fuse box in place. Lift up the fuse box so you get better access to the terminal ![]() Click image to enlarge Insert a short flat blade jewelers type screw driver under the pin in the direction of the red arrow for both the top and bottom pin (bottom not visible in photo) . Slide the cover off in the direction of the yellow item. |
Thank you Scott for a valuable tip!
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20761 ![]() ![]() |
I'd have thought that conduit should go to under that plastic cover under that brown cable.
That is leaving that section of cable more lulnerable than it should need to be for no valid reason. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
