Home > Maintenance & Modifications > C-post repair - diagonal section
excossack
Time has come to look at replacing the sloping section of the C-post (the section from the upright, diagonally down to the sill)
I have seen repair sections from YRM metal. Anyone else done this job whilst the c-post is still attached to the vehicle?
A quick look at doing the job and i need to remove;
The triangle section of external body work by removing the three rivets
Chequer plate sill cover
Two bolts that go through the seat base
Two spot welds towards the downward c-post section
Maybe some hidden spot welds behind the sill cover
I am sure there are more bits. Comments from more knowledgeable people required please 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #750142 9th Jan 2019 11:47am
Hufflepuff
I'm going to be tackling the same job myself later this year excossack.
I found the following video on YouTube which might help you:
He uses YRM parts, but things didn't line up too well in the end, which concerns me! (not that I suspect anything wrong with the YRM part, just the alignment of it all). 2005 Td5 90 XS
1989 V8 110 CSW
Post #750161 9th Jan 2019 1:15pm
excossack
Thanks HP. Are you planning on doing yours with the vehicle intact or you going the route of taking the 110 apart?
I would like to do it with out removing al the body work. I appreciate I will have to remove some parts such as door/seats 1999 Defender TD5 110
Regards
John M0VAZ
Post #750163 9th Jan 2019 1:23pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Mine need dong too, so I'll be watching this thread and hoping for useful information...
Post #750169 9th Jan 2019 2:22pm
lb73
Wales
I replaced both diagonal c sections on my 110csw using the yrm parts - which were spot on. Having removed the ali body parts I braced the door by making up some braces that could be bolted in place, also took some measurements before I cut the old metal out. From memory it was easy enough to weld back in place, just a bit awkward to get the welder in on the top section just below the door catch. Think there is a picture on page 3 of my build thread 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2002 Dax Rush 3.9 V8
2012 Audi A3 tdi
2020 Renault Kangoo electric
Post #750196 9th Jan 2019 6:00pm
Hufflepuff
Sorry for the delay in getting back to you. As my 110 currently consists of a chassis sitting on the garage floor waiting to be painted - I'll be taking the 110 apart Smile
There wasn't a lot of metal left on either side - believe it or not this was the better side of the two!
 2005 Td5 90 XS
1989 V8 110 CSW
Post #750443 10th Jan 2019 9:18pm
excossack
The better side...eeeeek! 1999 Defender TD5 110
Regards
John M0VAZ
Post #750457 10th Jan 2019 10:14pm
