Home > Maintenance & Modifications > C-post repair - diagonal section |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 |
I'm going to be tackling the same job myself later this year excossack.
I found the following video on YouTube which might help you: He uses YRM parts, but things didn't line up too well in the end, which concerns me! (not that I suspect anything wrong with the YRM part, just the alignment of it all). 2005 Td5 90 XS 1989 V8 110 CSW |
9th Jan 2019 1:15pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5857 |
Thanks HP. Are you planning on doing yours with the vehicle intact or you going the route of taking the 110 apart?
I would like to do it with out removing al the body work. I appreciate I will have to remove some parts such as door/seats 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
9th Jan 2019 1:23pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
Mine need dong too, so I'll be watching this thread and hoping for useful information...
9th Jan 2019 2:22pm |
lb73 Member Since: 27 May 2016 Location: North Wales Posts: 294 |
I replaced both diagonal c sections on my 110csw using the yrm parts - which were spot on. Having removed the ali body parts I braced the door by making up some braces that could be bolted in place, also took some measurements before I cut the old metal out. From memory it was easy enough to weld back in place, just a bit awkward to get the welder in on the top section just below the door catch. Think there is a picture on page 3 of my build thread 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
9th Jan 2019 6:00pm |
Sorry for the delay in getting back to you. As my 110 currently consists of a chassis sitting on the garage floor waiting to be painted - I'll be taking the 110 apart There wasn't a lot of metal left on either side - believe it or not this was the better side of the two! Click image to enlarge Click image to enlarge 2005 Td5 90 XS 1989 V8 110 CSW |
10th Jan 2019 9:18pm |
The better side...eeeeek! 1999 Defender TD5 110
10th Jan 2019 10:14pm |
