![]() | Home > In Car Electronics > Going to a double din |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
Currently have a Clarion NZ502e
Fantastic head unit.... just fancy a proper double din, I have a rather large audio setup in the truck sounds amazing... HDP4 powering focals front and rear, HDP1 powering a Hertz 380D all ran via proper audio cables etc... Few questions, whose double din is preferred? Twisted's is nice considering i already have there full interior i might as well? Other thing is, which head unit... Im currently stateside for another month is it worth buying over here or? I want something at the higher end of the scale... Thanks for the suggestions, |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
DefenderUpgrades.co.uk do a "Double Din Dashboard Centre Fascia Console Gloss Black With Movable Air Vents" and a pretty reasonable price (£210). Can't comment on the quality but not heard any bad things. It's the one I would go for. Then modify the side panel to remove the circular hole. Or better still don't use the side switch panel and relocated buttons to cubby with some of MCMA1 switch surrounds
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 389 ![]() ![]() ![]() |
I added this pod to shift the switches when I installed a flip out system. Would work for Double din too as you can add more switches instead of the gauge for example..
A bit of wiring but nothing too major. (hazzard switch conversion was more work but I prefer the look of the D2 switch) ![]() ![]() Click image to enlarge 2015 90 XS Santorini Black |
Not a fan of the pod on top, Ill take a look at the defenderupgrades option,
got a twisted cubby so don't fancy cutting into that... and a fair few extra switches for the Lazer LED gear. (all LR Aux switches) |
Puma_MOG Member Since: 08 Sep 2017 Location: Cheshire Posts: 184 ![]() ![]() ![]() |
Apologies if I understood it incorrectly, but by stateside, do you mean the US? If so, make sure that the radio/DAB will work here and that the maps do as well.
While it's been 10 yrs now, I once bought an EU factory navigation for a car I had in Canada which worked, however due to how address' are entered, that part didn't and I had to resort to coordinates. Good luck, P |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 ![]() ![]() ![]() |
I went for the Nakatenga surround , it’s great quality but the downside was having to cut the vents off the old one .
As above go for the defender upgrades one. Also worth noting that the aperture in the surround is for the smaller double din units and there are some that won’t fit. I’ve got the Pioneer SPH DA120 , great sound,CarPlay compatible and takes a reversing camera should you need it ! |
