Home > Puma (Tdci) > Rust..
Page 2 of 2 <12
gtveloce65
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Epsom Green
Yep, mine's starting to rust there as well - added to list...only 3 months of warranty left Shocked 1953 80
1965 Alfa Romeo GT Veloce Sprint
1980 Fiat 124 Spider
2008 110xs
Post #75014 9th Jun 2011 4:30pm
Froogle-Yorkshireman
2010 Defender 110 Puma 2.4 USW Stornoway Grey
Great this - got a new hobby - rust spotting...
My rust list:
Rust around door hinge boot rear door
Rust on rear door handle
Rust on rear step
Rust around tow bar
Rust rear cross member inserts
Rust mud flaps
Rust headlight housings
Rust on underside front bumper
Rust on Snorkel fixings
Rust A-Frame fixings
Rust on interior around door seals
Rust under interior rear carpets
Rust on exhaust
Rust on exhaust fixings
Rust on drive shaft
Chequer plate discoloration
Rust on chequer plate fixings corrosion
Rust on side steps
Wish I hadn't gone for Stornaway Grey now.... If I had gone for Orange it would all just blend in Laughing
All joking apart, glad I took advice from others on here and got mine waxoyl'd.
It will be interested to see any other ares of RUST concern anyone has. Proud owner 110 Utility XS
Ex RR Sport HST V8
Ex Td5 90
Post #75176 10th Jun 2011 10:35am
Zagato
Foot-well, but easy to sort.
Bonnet hinge to bulkhead not so easy to cure Sad
And just on this side under the corner or the capping bottom right hand rivet
Every single 60 plate Defender I looked at (about 10) had rust stains on the bonnet/bulkhead hinges and on the rear capping but only the right hand side - they were all the same just on the corner bit Rolling Eyes something was obviously not been done correctly for that side piece during production. I think a lot of the metal is already rusting before it is sprayed or it just isn't primed properly. Bare metal seems to be just spot welded on, then sprayed over. If you take that capping off I bet the ali panel underneath isn't even painted and I doubt there is little paint on the underside of the capping's themselves if any at all Rolling Eyes
I have cleaned the brown staining on mine and it hasn't come back again but you dread to think whats going on underneath. I've sprayed all my possible rusty bits with Wurth rust prevention spray. Hinges, seat frame, internal bolts, screws, winch, tow bar bits, under bonnet etc everywhere in fact that has a nut,bolt,or screw!
Before it gets too bad I will drill out the bulkhead hinges and get them galvanised along with the capping's - probably in a couple of years - the rust staining hasn't come back after two months so if it is corroding it is doing so slowly!
ANYONE ELSE MISSING THOSE RIVETS?
Post #75182 10th Jun 2011 11:07am
Grockle
Scallops wrote:
Heya Grock! Did the dealers pick this up when they did their "annual corrosion inspection", or was it down to your own diligence?
Hi Dan,hope you had a good time in Canada,I noticed the corrosion whilst cleaning it. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #75183 10th Jun 2011 11:45am
Had a load of warranty work completed by Hillendale - They were great and offered excellent service.
Rust around door hinge boot rear door - flushed and waxoyl'd
Rust on rear door handle - replaced
Rust on rear step - replaced
Rust around tow bar - replaced
Rust rear cross member inserts - repainted
Rust mud flaps - replaced
Rust headlight housings - replaced
Rust on underside front bumper - complete bumper replaced
Rust on Snorkel fixings - complete Snorkel replaced
Rust A-Frame fixings - complete A-Frame replaced
Rust under interior rear carpets - cleaned and waxoyl'd
Chequer plate discolouration - all chequer plate replaced
Rust on side steps - replaced
So the warranty certainly lives up to expectations. Hillendale also found a small oil leak on the rear axle and my park brake was contaminated reference the recall. Proud owner 110 Utility XS
Ex RR Sport HST V8
Ex Td5 90
Post #78681 2nd Jul 2011 9:11am
mse
The hinge section (front and rear) are because the 2 bits of ali/metal are not painted underneath.
If you want to fix it - remove them and paint underneath.
I had them fix the bulkhead hinges at 14months old and i know about the rear hinge mounts when i took them off to change a td5 from a pickup to a van and had to remove the drop down tailgate Mike
Post #78686 2nd Jul 2011 9:29am
Zagato
Good to hear the dealership took the correct action for you Froogle Thumbs Up The immediate thing now is to spray your chosen anti-rust potion over the past offending untreated areas before they corrode again after warranty Shocked ACF-50 or Wurth Anti-Corrosion Spray etc Thumbs Up
Post #78717 2nd Jul 2011 3:23pm
Happyoldgit
Lucky you've got an obliging dealer Froogle. Steve.
http://forums.lr4x4.com
Post #78719 2nd Jul 2011 3:38pm
Good tip Zagato Thumbs Up
Does the ACF-50 damage rubber seals? Also does it leave a sticky residue?
I'm thinking if I sprayed it all over the tow bar and rear step would it be an issue for attracting dust and dirt. Proud owner 110 Utility XS
Ex RR Sport HST V8
Ex Td5 90
Post #78775 3rd Jul 2011 8:18am
Green Machine
That's what I do to mine now that I have had various things properly treated and re-sprayed. It isn't 'sticky' especially, it's pretty much the same consistency as WD40 - not quite as thin. So it leaves a 'film' of oil over the surface, which does attract dust slightly, but not significantly so. The main thing is that all the dust, road film, salt etc. is being separated from the paintwork and metal underneath by the layer of ACF-50. Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #78777 3rd Jul 2011 8:44am
K9F
Grockle wrote:
..ing under the bottom corners of the windscreen rubber,check yours,have booked it in again !
Ditto.....
My rust list over the preceding three years reads pretty much like yours...My vehicle has just spent the last week (still in as I type) having the last 'touches' done having been over it thoroughly...Almost an identical thread...
http://www.defender2.net/forum/topic6310.h...p;start=45 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #78780 3rd Jul 2011 9:07am
Page 2 of 2 <12
